developing drivers for custom boards
- btvpimill
- Thank you received: 3
26 Mar 2013 00:41 #31868
by btvpimill
Replied by btvpimill on topic developing drivers for custom boards
Thanks Andy, that makes a lot more sense to me now. At this point the count function is only there because of borrowed code from you or another driver. I actually only have a need for 1 card connected to it at this time (my card can drive 10 steppers), but I do like the idea of more than 1.
Currently I have some conversation happening between hal and my card. I am getting some data from hal, and hal is getting some back. Best of all, nothing is locking up yet
I have some buffer issues in my card right now, but I am sure that is something dumb and I will sort it out quickly.
Once I sort that out, I will be back with more questions like how can I pass some arguments to extra setup for card configure (I think just like ioaddr is passed), and how do I pass a pin that is not a bit?
I want my byte3 to actually be a spindle speed between 0-255. I am sure that is trivial to all but me.
- btvpimill
26 Mar 2013 05:10 #31879
by btvpimill
Buffer issues fixed!!! I can now send and receive 4 bytes of data.
Thanks to all (Andy,Peter,John, and more) who have held my hand and gotten me this far
On to the next things - in my extra setup, I want to send some config data. I would like to pass it from config.hal, but not sure how to do that.
also need to work out how to have 1 of the bytes be my spindle speed.
Any help for this??
Any help for this??
- Thank you received: 5017
26 Mar 2013 06:06 #31880
Create a float pin and a float scale parameter.
Mutiply the pin value by 256 then divide by the scale into a byte, then send the byte.
Replied by andypugh on topic developing drivers for custom boards
I am not even sure what you mean.On to the next things - in my extra setup, I want to send some config data. I would like to pass it from config.hal, but not sure how to do that.
That's easier.also need to work out how to have 1 of the bytes be my spindle speed
The following user(s) said Thank You: btvpimill
- btvpimill
26 Mar 2013 06:29 #31881
by btvpimill
for instance, I want to send 3 bytes to my card but only when Linuxcnc is started. this will be step size info and what drives will be used. So in my hal file I want something like this:
steps=0xff,0xc2
drives=0xff
similar to how we have
ioaddr=0x378
then in my extra_setup I want to have:
outb(steps[0],base_addr+4)
outb(steps[1],base_addr+4)
outb(drives,base_addr+4)
I hope this makes more sense. I will chew on the spindle part and see what I can do.
steps=0xff,0xc2
drives=0xff
ioaddr=0x378
26 Mar 2013 06:40 - 26 Mar 2013 06:40 #31882
The code that does this is:You need to addAnd the same for drives (possibly).
You can then index into the arrays with the extra_arg as required to get the data.
To add some auto-documentation use something similar to your current:There is some support in "comp" for modparams, but only integers (and it is undocumented, and may not work). This example uses "dummy" to create only the documentation, and then the actual modparam is created with the RTAPI_MP_ARRAY_XXXX macros.
steps=0xff,0xc2
drives=0xff
ioaddr=0x378
static int ioaddr[MAX_CHAN] = {-1, -1, -1, -1, -1, -1, -1, -1};
RTAPI_MP_ARRAY_INT(ioaddr, MAX_CHAN, "Base addresses")
static int steps
RTAPI_MP_ARRAY_INT(steps, MAX_CHAN, "some comment here")
modparam dummy ioaddr """Base address of card. Separate each card base address
with a comma but no space to load more than one card. eg
loadrt custepp ioaddr=0x378,0xdf00. use 0xNNN to define addresses in Hex""";
Last edit: 26 Mar 2013 06:40 by andypugh.
- btvpimill
26 Mar 2013 06:54 #31883
by btvpimill
Well it doesn't even have to be an array, but I will give it a whirl tomorrow when I get to work. it could be a 3 byte array and just need 1 variable that way:
for instance.
I will look for this extra_arg to see what this is.
cardconfig=0x23,0x45,0xff
26 Mar 2013 07:14 #31884
You tend to have one argument for every Instance of the component.
Comp rather hides this complexity from you.
The code in EXTRA_SETUP is called once for each instance of the component.
Typically you would need to look at ioaddr[extra_arg] to make sure that the setup data for each instance of the component was sent to the correct card port.
And the same for any other modparams that you use.
"extra_arg" is a variable that you can use in EXTRA_SETUP to get the index of the current instance.I will look for this extra_arg to see what this is.
- btvpimill
26 Mar 2013 07:35 #31885
by btvpimill
thank you ahead of time for you patience, I think I either don't understand, haven't explained it correctly, or am trying to use the tools wrong. Prolly all 3
My card will send step/dir signals to as many as 10 drive cards. (linuxcnc can control 9 and 1 slave or any variation)
the step size is programmable per drive (ie microstepping half,fourth,eighth,or sixteenth)
in a given machine configuration, I may want to only use 5 drives with 2 at eighth step and 3 at quarter step
So there would only need to be 1 instance of the comp, but in the extra_setup I thought I could send the data needed for the step size and drive enables. Now this enable is not to be confused with the regular amp_enable pin, that will be used to turn all the enabled drives on.(in above example that would be 5)
This data only needs to be sent once when axis is started hence my idea to use the extra_setup section. So my question is how to get that data from hal file to comp so the comp file is generic to my card.
I hope this makes sense, and maybe this is what you answered. So then I just do not fully understand yet and need to play to see the results.
26 Mar 2013 07:50 #31886
How you encode it is entirely up to you.
Send it as a modparam, as discussed.This data only needs to be sent once when axis is started hence my idea to use the extra_setup section. So my question is how to get that data from hal file to comp so the comp file is generic to my card.
- btvpimill
26 Mar 2013 23:15 #31930
by btvpimill
So far I have my array working to pass some values (12 in all) that get sent to my card. This is FUN STUFF!!!
Now, in my clueless way, I seem to have almost filled my 4G HDD. I can only assume this is from my blantent use of RTAPI_PRINT running in a thread. So anybody know where this is stored and how to get rid of it?
Time to create page: 0.180 seconds
