developing drivers for custom boards
25 Mar 2013 07:04 - 25 Mar 2013 07:35 #31815 by btvpimill
Replied by btvpimill on topic developing drivers for custom boards
Well here is a blast from the past. I am finally back to this project.
So of course the first thing I try is to install my comp file, but seems no matter where I try from, using "sudo comp --install path/FC_epp.comp" gets me:
sudo: comp: command not found
I have not tried ' install the emc2-dev (sudo apt-get install emc2-dev) and build-essential packages (sudo apt-get install build-essential)' from section 1.3 here . I don't remember doing that before when this was all emc2. Do I need to now?
Went ahead and did both those steps, now I get this:
rev3@rev3:~/linuxcnc$ sudo comp --install FC_epp.comp
File "/usr/bin/comp", line 1335, in <module>
main()
File "/usr/bin/comp", line 1304, in main
process(f, mode, outfile)
File "/usr/bin/comp", line 1178, in process
a, b = parse(filename)
File "/usr/bin/comp", line 411, in parse
a, b = f.split("\n;;\n", 1)
ValueError: need more than 1 value to unpack
Guess I am lost. I am sure it is something dumb, but maybe someone will see it.
Oh Dear, I see this is the same issue I was having on page 3 of this thread. Well off to find the magic I ran across on page 4.
Last edit: 25 Mar 2013 07:35 by btvpimill.
25 Mar 2013 10:53 #31822 by btvpimill
The magic has been solved. I never noticed gedit has a dropdown box to pick the line endings when it saves a file. As I had been opening the file as a txt to start with, that defaulted to windows style.
Save as and pick the unix/linux and it compiles now :)
I guess I will start trying to get it to work tomorrow
25 Mar 2013 11:55 #31824 by btvpimill
well before going to bed, I tried to load my driver and see if that much worked, failed.
after I did the comp -- install FC_epp.comp
everything seemed to work - I guess. no errors
then I tried halrun
halrun : loadrt FC_epp ioaddr=0x378
I get an error saying too many parameters or something. checked dmesg, I see that at least it got to EXTRA_SETUP, in djesg I see the output:
"loading epp at base address 378"
But that is all. done for the night. Thanks for any insight anyone can provide for this.
25 Mar 2013 19:57 #31841 by andypugh
Replied by andypugh on topic developing drivers for custom boards
That might just be EXTRA_SETUP returning a non-zero value.
25 Mar 2013 20:05 - 25 Mar 2013 20:09 #31842 by btvpimill
here is my EXTRA_SETUP
EXTRA_SETUP(){
if (ioaddr[extra_arg] > 0) {
base_addr = ioaddr[extra_arg];
rtapi_print("Loading EPP custom board driver at base addr %X\n", base_addr);
return 0;
return -EINVAL;
int get_count(void){
int i;
for (i=0; ioaddr > 0 && i < MAX_CHAN; i++){}
return i;
Not sure what would be wrong here. Also have no idea how the last 4 lines get called to return i
BTW, I am running the code found on page 4 of this thread
Last edit: 25 Mar 2013 20:09 by btvpimill. Reason: Added where the code is
25 Mar 2013 20:28 #31845 by andypugh
EXTRA_SETUP(){
return 0;
return -EINVAL;
I would suspect that this is dropping through to the "return -EINVAL". Inserting an rtapi_print will make that clear.
int i;
return i;
get_count is called if you have option count_function yes set.
But it looks to be in danger of always returning MAX_CHAN as ioaddr is likely to be a non-zero pointer to the ioaddr array.
You might want ioaddr > 0 instead.
Always returning MAX_CHAN for the channel counts will explain why the EXTRA_SETUP fails.
25 Mar 2013 21:42 #31851 by btvpimill
Here is my new EXTRA_SETUP:
EXTRA_SETUP(){
outb(4,base_addr+2);
rtapi_print("made it past EPP setup\n");
return 0;
rtapi_print("Seems we are returning -EINVAL\n");
return -EINVAL;
int i;
rtapi_print("down here in get count, i = %X\n", i);
return i;
and the error messages from dmesg:
[  529.285281] RTAI[math]: loaded.
[  549.441699] down here in get count, i = 8
[  549.441719] Loading EPP custom board driver at base addr 378
[  549.441728] made it past EPP setup
[  549.442084] Seems we are returning -EINVAL
[  549.442091] Seems we are returning -EINVAL
[  549.442096] Seems we are returning -EINVAL
[  549.442102] Seems we are returning -EINVAL
[  549.442107] Seems we are returning -EINVAL
[  549.442112] Seems we are returning -EINVAL
[  549.442120] Seems we are returning -EINVAL
[  563.704436] RTAI[math]: unloaded.
[  563.748774] SCHED releases registered named ALIEN RTGLBH
[  563.808594] RTAI[malloc]: unloaded.
[  563.908032] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[  563.913767] I-pipe: Domain RTAI unregistered.
[  563.913940] RTAI[hal]: unmounted.
Any ideas? I am not sure what you ment with change it to ioaddr > 0, where?
25 Mar 2013 22:20 #31855 by btvpimill
I set option count_function to no, and now all seems to work. so moving forward but still would like to know why it does not work
25 Mar 2013 23:28 #31861 by andypugh
You have a count function, you probably ought to use it.
However, the count function isn't right. It keeps counting as long as there is an ioaddr array, not as long as the elements of the ioaddr array are valid.
swap
for
for (i=0; ioaddr[i] > 0 && i < MAX_CHAN; i++){}
and set option cont function back to yes.
This is assuming that the ioaddr modparam actually exists and is what is being used.
25 Mar 2013 23:30 - 25 Mar 2013 23:30 #31863 by andypugh
That was rendered unclear by the forum formatting eating my index. It probably ate yours too. :-)
Last edit: 25 Mar 2013 23:30 by andypugh.
Moderators: PCWjmelson
Time to create page: 0.070 seconds
