developing drivers for custom boards
09 Aug 2011 19:07 - 09 Aug 2011 19:11 #12351 by andypugh
Replied by andypugh on topic Re:developing drivers for custom boards
It just worked fine for me, on a stock install. The errors are there, but it still loads with halrun.
What does dmesg say after your attempted loadrt?
do you see the highlighted line below?
andypugh@ubuntu:~/emc2$ sudo comp --install constant.comp
make -C /usr/src/linux-headers-2.6.32-122-rtai SUBDIRS=`pwd` CC=gcc V=0 -o /Module.symvers modules
make[1]: Entering directory `/usr/src/linux-headers-2.6.32-122-rtai'
CC [M] /tmp/tmpmKP5S1/constant.o
Building modules, stage 2.
MODPOST 1 modules
WARNING: "hal_init" [/tmp/tmpmKP5S1/constant.ko] undefined!
WARNING: "hal_exit" [/tmp/tmpmKP5S1/constant.ko] undefined!
WARNING: "hal_export_funct" [/tmp/tmpmKP5S1/constant.ko] undefined!
WARNING: "hal_malloc" [/tmp/tmpmKP5S1/constant.ko] undefined!
WARNING: "hal_pin_bit_newf" [/tmp/tmpmKP5S1/constant.ko] undefined!
WARNING: "rtapi_snprintf" [/tmp/tmpmKP5S1/constant.ko] undefined!
WARNING: "hal_ready" [/tmp/tmpmKP5S1/constant.ko] undefined!
WARNING: "hal_pin_u32_newf" [/tmp/tmpmKP5S1/constant.ko] undefined!
WARNING: "rtapi_print" [/tmp/tmpmKP5S1/constant.ko] undefined!
CC /tmp/tmpmKP5S1/constant.mod.o
LD [M] /tmp/tmpmKP5S1/constant.ko
make[1]: Leaving directory `/usr/src/linux-headers-2.6.32-122-rtai'
cp constant.ko /usr/realtime-2.6.32-122-rtai/modules/emc2/
andypugh@ubuntu:~/emc2$ halrun
halcmd: loadrt constant ioaddr=0x378
halcmd: show pin
Component Pins:
Owner Type Dir Value Name
3 u32 OUT 0x00000000 constant.0.R0-in
3 u32 OUT 0x00000000 constant.0.R0-out
3 u32 OUT 0x00000000 constant.0.R1-in
3 u32 OUT 0x00000000 constant.0.R1-out
3 u32 OUT 0x00000000 constant.0.R2-in
Last edit: 09 Aug 2011 19:11 by andypugh.
09 Aug 2011 19:11 #12353 by BigJohnT
Replied by BigJohnT on topic Re:developing drivers for custom boards
andypugh wrote:
This probably isn't the problem, but "constant" is a bad choice of name, as that is a pre-existing hal module.
I just grabbed the example out of the HAL manual... might be a bad example.
09 Aug 2011 19:19 #12354 by btvpimill
Replied by btvpimill on topic Re:developing drivers for custom boards
well I tried it again, but I cd'd to emc2 directory (I was in configs). Seems to work the same as Andy shows. So I guess I am now back at square 2. :)
Still need to study tonight to figure out how to add the EPP port setup to my comp file. Then maybe I will be able to talk to my card
10 Aug 2011 10:06 #12372 by btvpimill
Now that I've had a good sleep, and maybe some digestion of all my reading last night, here is my next question.
Does the port set-up refered to by PCW go in the EXTRA_SETUP section? This makes sense to me based on how I understand the comp descripton page. If this is so, would it go like this:
EXTRA_SETUP(){
if (ioaddr[extra_arg] > 0) {
base_addr = ioaddr[extra_arg];
rtapi_print("Loading EPP custom board driver at base addr %X\n", base_addr);
INSERT PORT SETUP HERE
return 0;
return -EINVAL;
And if not, I just don't understand how to invoke the port setup within the comp file. When I get to work, I am going to compare the .c generated by comp to the examples listed in the first page. Now that I realize they are straight C, it may make more sense.
10 Aug 2011 10:33 #12373 by andypugh
Yes that is exactly what it is for.
EXTRA_SETUP gets macro-expanded in the generated C-code and is called once per-instance. So if you loadrt 2 of your comp, EXTRA_SETUP will get called twice.
You can use the extra_arg variable to differentiate which instance is being set up. (as your code shows), but in your case, and for your own use, you could use the pre-defined "personality" modparam for the ioaddr and keep things a bit simpler. I have tended not to, so that the modparam name is a little more self-explanatory. I can think of good arguments to switch from "personality" to "cfg" for the pre-defined name too, but it is now too late.
10 Aug 2011 11:15 #12374 by btvpimill
Oh THANK YOU for that. I have been going nuts trying to figure out WHERE to put the tid-bit of code needed to get the port initalzied.
I don't understand what you mean by this:
Are you just saying I could have just hardcoded the ioaddr, then I would not need the original part of the extra setup? I would like to keep that part, as I think that is the part of how to specify the address from my hal file. I want to be able to do this so I can use a PCI card instead of the built in port. But maybe that is not what it is doing at all.
If I have this wrong, could you explain that a little bit more for me?
10 Aug 2011 12:04 #12377 by andypugh
I mean that you could use:
option personality;
and then
loadrt mycomponent personality=0x378
and then just use "personality" everywhere you want the base address instead of ioaddr[extra_arg] and leave out the modparam parsing code at the beginning of the function.
10 Aug 2011 22:33 #12388 by btvpimill
Well Finally just befor leaving work, I tried this out:
outb(4,base_add+2)
I put this just before the RETURN 0 in the extra setup. Much to my surprize,
IT WORKED!!!!!!!!!!!!!:woohoo: :woohoo:
Now there is much more work to be done, but I think at least for now I have some control over things.
Thanks everyone, I am 1 happy man right now!!
11 Aug 2011 22:40 #12441 by andypugh
btvpimill wrote:
IT WORKED!!!!!!!!!!!!!:woohoo: :woohoo!
Once you get things working you tend to notice that, actually, it is quite easy if you do the right things in the right order.
11 Aug 2011 23:10 #12442 by btvpimill
Yes that is very true. And thanks to you guys, I am closer to getting that order right.
The next order of business for me is to finish modifying John's ptest to test all 32 pins. I started to do that today, but must have messed up something. I can change things around in his, for using different io pins, but when I wrote all 64 pins into it, it quit working. More with that tomorrow.
Moderators: PCWjmelson
