Mesa 5i20 - 7I52S support
07 Dec 2011 09:09 #15439 by cmorley
Replied by cmorley on topic Re:Mesa 5i20 - All pins at +5V
Peter if you can supply the PIN file for the 7i52 firmware I probably can convince PNCconf (from version 2.5) to configure all but the offset comp.
07 Dec 2011 15:17 #15445 by PCW
Replied by PCW on topic Re:Mesa 5i20 - All pins at +5V
If the BIAS is added, it should be 234 (so a -234 mm/sec velocity request from the PID output is translated to a 0 PWM value)
In addition the PWM scale should be set to 468 and the PID components MAX_OUTPUT should be set to 234 (that way the PIDs requested -234 velocity generates 0 PWM and +234 velocity generates 468 = full scale PWM)
I'm not sure how they are applied but there are already provisions output offsetting (OUTPUT_OFFSET)
Note that if it works it would have the opposite sign of your (added) BIAS (-234) since it its subtracted
As far as bitfiles are concerned, I would have to build a bit file. I would probably make the output pairs on the 7I52S PWM and ENABLE
08 Dec 2011 00:11 #15463 by PCW
freeby.mesanet.com/sv6la.zip
contains the bit file/ pin file and changed pin-out vhdl source
08 Dec 2011 23:18 #15505 by boyzo
Replied by boyzo on topic Re:Mesa 5i20 - All pins at +5V
PCW, thank you..
Now I might need some help with HAL config ( what to change in pncconf)
09 Dec 2011 01:04 #15507 by cmorley
What version of EMC are you using?
09 Dec 2011 08:30 #15510 by boyzo
Currently I am using compiled version 2.4.6. I can also install 2.5 if required.
09 Dec 2011 20:21 #15523 by PCW
You will need 2.5 to support the 7I52s muxed encoders
10 Dec 2011 09:06 - 10 Dec 2011 09:23 #15526 by cmorley
ok when you have EMC 2.5
I hand wrote a stripped down XML file for the firmware Peter supplied.
download this file and unzip it in the folder ( /lib/firmware/hm2/5i20 ) that has the BIT firmware files in it (you need sudo power)
then run pncconf. The first page should say beta1 - thats the right version
you should find the firmware in the firmware combo box.
let me know how it worked.
Chris M
File Name: SV6LA_7I52S.zip
File Size:1 KB
Last edit: 10 Dec 2011 09:23 by cmorley.
11 Dec 2011 10:43 #15544 by boyzo
It works without problems. Looking at the README file, There is only one pin for each encoder. To my understanding, there should be at least INDEX pin as well?
The following is pncconf README output
P2-1 0 (0 GPIO Input) unused-input
P2-3 1 (0 Muxed Encoder 0) x-encoder-a
P2-5 2 (0 Muxed Encoder 1) y-encoder-a
P2-7 3 (0 muxed enc) unused-encoder
P2-9 4 (1 Muxed Encoder 0) z-encoder-a
P2-11 5 (1 Muxed Encoder 1) s-encoder-a
P2-13 6 (1 muxed enc) unused-encoder
HAL file is attached
File Name: my_EMC_machine.hal
File Size:10 KB
11 Dec 2011 15:24 #15550 by PCW
Here's a part of the .PIN file (which is read from the IDROM and indicates the internal FPGA wring)
So I suspect everything will work but it looks like pncconf doesn't recognize Muxed counter indexes
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort None
3 1 IOPort MuxQCnt 0 MuxQ-A (In)
5 2 IOPort MuxQCnt 0 MuxQ-B (In)
7 3 IOPort MuxQCnt 0 MuxQ-IDX (In)
9 4 IOPort MuxQCnt 1 MuxQ-A (In)
11 5 IOPort MuxQCnt 1 MuxQ-B (In)
13 6 IOPort MuxQCnt 1 MuxQ-IDX (In)
15 7 IOPort MuxQCnt 2 MuxQ-A (In)
17 8 IOPort MuxQCnt 2 MuxQ-B (In)
19 9 IOPort MuxQCnt 2 MuxQ-IDX (In)
21 10 IOPort MuxQSel 0 MuxSel0 (Out)
Note because of the Muxed encoders there are only about 1/2 as many interface pins as encoders signals. That is the interface signals MuxQ-A0,MuxQ-B0, and MuxQ-IDX0 support encoder channels 0 and 1
Moderators: PCWjmelson
Time to create page: 0.072 seconds
