Mesa 5i20 - 7I52S support
- boyzo
- Thank you received: 3
22 Dec 2011 20:39 #15950
by boyzo
Replied by boyzo on topic Re:Mesa 5i20 - All pins at +5V
We manage to repair (remove resistors) from the board and it behaves much different.
Now I am somehow confused with tunning. VSD/E drive contain its own PID loop (I configured the drive in velocity mode) and it runs super with supplied SW.
With EMC close loop I have problems. How EMC PID works with drive PID? I can run with P=5 or 6, I=0, D=0. I define following error 0.5, if less, I receive error. What is reasonable value.
I believe that I can not correctly tune EMC as motor alone works much better.
- Thank you received: 5251
22 Dec 2011 21:05 #15951
Replied by PCW on topic Re:Mesa 5i20 - All pins at +5V
Removing the resistors should have made no operational difference (only increasing the output drive voltage slightly say from 4.3v to 5V)
Is the drive still in velocity mode (PWM in sets velocity?)
For velocity mode (and if scaled properly, that is PID feedback, command and output are all in machine units per second (234?)) FF1 needs to be set to 1 and then adjusted a little (say from 0.90 to 1.10) for lowest following error during a fast slew.
Also I believe theres an optional filter in the Granite drive from input command to their velocity loop.
This needs to be turned off
- Ekke
29 Dec 2011 09:12 #16069
by Ekke
Replied by Ekke on topic Re:Mesa 5i20 - All pins at +5V
boyzo wrote:
I have 5i20 & 7i52 (without S for now, I will try to mod it to S-version) & Granite VSD-E & "their" BLCD servos so I'm really keen to follow your progress. Any updates?
It seems I am trying to do some not so ordinary configuration, but this might help someone else as well.
Bojan
- boyzo
29 Dec 2011 13:05 #16073
by boyzo
Ekke wrote:
Following guidelines from this forum (thanks to all help from Andy, Cmorley and PCW
) I was able to get to the point where I am OK for now. I need to do real test on the machine. The following is my definitions:
setp hm2_5i20.0.pwmgen.02.scale 480
setp scale.y.offset -240.2 With this I get 0.000 standstill position at drive enable, with -240 always some offset (0.003). Drive is almost steel, flicker on 0.000 - 0.001 every several seconds.
scale.y.gain - not sure what value to put there.
P=6, D=0, I=0, FF0, FF1 and FF2 all zero. It was suggested that FF1 needs to be set to 1, but with any value in FF1 I get following eror.
Other parameters:
FERROR = 1.3
MIN_FERROR = 0.1
MAX_VELOCITY = 180.00
MAX_ACCELERATION = 1000.00
I am not happy with high rapid following error, also min ferror seems high, but checking it with G1 Y500 F1800 keep ferror below 0,05.
Other parameters:
FERROR = 1.3
MIN_FERROR = 0.1
Time to create page: 0.066 seconds
