Mesa 5i25 config for chinese BOB
- Thank you received: 5295
16 Apr 2016 20:11 #73427
Replied by PCW on topic Mesa 5i25 config for chinese BOB
take a look at the .pin files in the 5i25 distribution zip file
These show all the available configuration pinouts
5i25_g540x2.pin
5i25_hdbb2.pin
5i25_mx3660x2.pin
5i25_prob_rfx2.pin
5i25_r990x2.pin
are likely suspects
5i25_g540x2.pin
5i25_hdbb2.pin
5i25_mx3660x2.pin
5i25_prob_rfx2.pin
5i25_r990x2.pin
are likely suspects
- pacman13b
16 Apr 2016 20:35 #73429
by pacman13b
Replied by pacman13b on topic Mesa 5i25 config for chinese BOB
Thanks PCW , give me 5 minutes of your time...I'll take a quick peek..
- pacman13b
16 Apr 2016 20:46 #73432
by pacman13b
I'll give 5i25_hdbb2.pin a go right now and I;ll let ya know..
- pacman13b
16 Apr 2016 21:08 #73433
by pacman13b
PCW, I flashed it all ok but it's not comming up in the firmware for pcnconfig. I'mm using linuxcnc 2.7, do I have to copy some file over to a sub dir or something..?
16 Apr 2016 21:31 #73436
I dont think you can use pncconf,
you will have to take a close pncconf created config
or a standard linuxcnc sample config as a starting point
and do the rest by editing the hal/ini files
- pacman13b
16 Apr 2016 21:47 #73439
by pacman13b
I'll give that a go. If I fail Imm gona switch to a 7i76E I have on the side.. I'll have to dig up some docs on creating HAL & INI files for linuxCNC. It's just a lot of work to re-wire all the setup for the ethernet... I was hoping someone might have a similar setup with config files.
Thanks for all the help..
- eFalegname
- Thank you received: 30
17 Apr 2016 10:05 - 17 Apr 2016 10:09 #73465
by eFalegname
I'm glad you found the right configuration to the 5i25 - chinese combo, but since the spirit of the forum is to share it would be good to post it . Would you be willing to share your files, please?
So others who find this post get the solution too.
Replied by eFalegname on topic Mesa 5i25 config for chinese BOB
Thank you all for help
a cute Forummember helps me to fit the 5i25 to Benezan bob and chinese bob too
THANK YOU Sarah
take a look
and here
i will come back sone to look for further help in an Kinematic Problem
Thank you and have a nice day
ROL
Last edit: 17 Apr 2016 10:09 by eFalegname.
- pacman13b
17 Apr 2016 18:37 #73499
by pacman13b
Can you share please ..
THANK YOU Sarah
take a look
and here
ROL
- eFalegname
17 Apr 2016 18:41 - 17 Apr 2016 18:43 #73500
by eFalegname
pacman13b??
"G0G53Z148" Roland is the man we need
Last edit: 17 Apr 2016 18:43 by eFalegname.
- G0G53Z148
- Thank you received: 6
18 Apr 2016 05:24 #73511
by G0G53Z148
Replied by G0G53Z148 on topic Mesa 5i25 config for chinese BOB
Takee the r990 conect du the outer Port and config your pins with pncconf
Thats all what i have done
The rest ist a little bit of testinig i spend a lot of teime here to find nothing out
I know i5 gives a lot of peope how can help but sorry there is mist time only one how wants. The rest are only steamtalker linux could be a great System but the menthality of the KNOWING people is so i know it an you can study
Most time only one line is wrong the erote a lot of text and post the shity documentation link
Whe he now it why he dos not post the reason? It will be less time and no waste traffic
Big big shit so sorry
Time to create page: 0.096 seconds
