Mesa 5i25 config for chinese BOB
- Thank you received: 5326
20 Apr 2016 18:50 #73658
Replied by PCW on topic Mesa 5i25 config for chinese BOB
If you dont have the latest PnCConf version, it will set the PID P terms to 50
These need to be set to 1000 in the ini file for a 1 KHz servo thread
- pacman13b
21 Apr 2016 07:40 #73677
by pacman13b
Replied by pacman13b on topic Mesa 5i25 config for chinese BOB
Got it.. Can't find that in the manual comes from experience..
Great Thnx....
Looks like it is comming alive to a real pro-CNC, I have backed up my setup and how to set mesa gpio to parallel etc.. ALL looks good. Anyone needs info I'll be here..
I also have a wireless renishaw probe has anyone hooked this up. Since I have it I think I'll try to hook it up for tool probe and workpiece probing..
Thank you all..
Great Thnx....
Thank you all..
The following user(s) said Thank You: G0G53Z148
- G0G53Z148
- Thank you received: 6
21 Apr 2016 14:43 #73692
by G0G53Z148
Replied by G0G53Z148 on topic Mesa 5i25 config for chinese BOB
Then have you done a big step forward concrats and at sencond you can read the linuxcnc dokumentation native:)
i have to hobble from point to point but in a view years i will have it done
have a nice day and greez from austria
- pacman13b
21 Apr 2016 20:53 #73697
by pacman13b
Thank u,,Then have you done a big step forward concrats and at sencond you can read the linuxcnc dokumentation native:)
- eFalegname
- Thank you received: 30
29 Jan 2018 14:47 - 29 Jan 2018 14:50 #105156
by eFalegname
Replied by eFalegname on topic Mesa 5i25 config for chinese BOB
Hi PeterW,
I finally could make the configuration file .bit for the chinese BOB (I get only some warnings not errors from ISE).
Now I have an issue with the 6i25 mesa board when I switch on the PC if the 6i25 and the chinese board are connected together the PC won't start.
The jumper W5 is in the up position, but if the 6i25 is not connected when I switch on the PC, it will start but the 6i25 won't load my custom file and go for its default.
If I upload the custom file again the 6i25 and my CNC Router work as expected until the next time the computer is turned on.
Here I attach the custom file so you can check please if there is any error.
Thank you very much for your time and dedication.
Floris
Floris
Last edit: 29 Jan 2018 14:50 by eFalegname.
29 Jan 2018 14:59 #105157
Make sure you dont have the cable power options enabled on the 6I25, that is, make sure W1 and W2
are in the down position.
There is no reason to ever change W5 unless you are doing bridge firmware updates
If your bitfile will not load, ( and the fallback config loads instead = blinking red light )
this means the bitfile failed the CRC test either because it's corrupted or it is for the wrong FPGA
- eFalegname
29 Jan 2018 15:16 #105158
by eFalegname
I will try to make it all over again downloading the file 5i25.zip from your site. I have chosen to modify the project ifive and my file is working perfectly, the only issue is I can't shut the PC down.
constant PinDesc : PinDescType :=(
-- Base func sec unit sec func sec pin -- external DB25
IOPortTag & x"00" & PWMTag & PWMAOutPin, -- I/O 00 PIN 1 PWM
IOPortTag & x"00" & NullTag & NullPin, -- I/O 01 PIN 14 just GPIO
IOPortTag & x"00" & StepGenTag & StepGenStepPin, -- I/O 02 PIN 2 X Step
IOPortTag & x"00" & NullTag & NullPin, -- I/O 03 PIN 15 just GPIO
IOPortTag & x"00" & StepGenTag & StepGenDirPin, -- I/O 04 PIN 3 X Dir
IOPortTag & x"00" & NullTag & NullPin, -- I/O 05 PIN 16 just GPIO
IOPortTag & x"01" & StepGenTag & StepGenStepPin, -- I/O 06 PIN 4 Y Step
IOPortTag & x"00" & NullTag & NullPin, -- I/O 07 PIN 17 just GPIO
IOPortTag & x"01" & StepGenTag & StepGenDirPin, -- I/O 08 PIN 5 Y Dir
IOPortTag & x"02" & StepGenTag & StepGenStepPin, -- I/O 09 PIN 6 Z Step
IOPortTag & x"02" & StepGenTag & StepGenDirPin, -- I/O 10 PIN 7 Z Dir
IOPortTag & x"03" & StepGenTag & StepGenStepPin, -- I/O 11 PIN 8 A Step
IOPortTag & x"03" & StepGenTag & StepGenDirPin, -- I/O 12 PIN 9 A Dir
IOPortTag & x"00" & NullTag & NullPin, -- I/O 13 PIN 10 just GPIO
IOPortTag & x"00" & NullTag & NullPin, -- I/O 14 PIN 11 just GPIO
IOPortTag & x"00" & NullTag & NullPin, -- I/O 15 PIN 12 just GPIO
IOPortTag & x"00" & NullTag & NullPin, -- I/O 16 PIN 13 just GPIO
-- 26 HDR -- IDC DB25
IOPortTag & x"01" & PWMTag & PWMAOutPin, -- I/O 17 PIN 1 PIN 1 PWM
IOPortTag & x"00" & NullTag & NullPin, -- I/O 18 PIN 2 PIN 14 just GPIO
IOPortTag & x"04" & StepGenTag & StepGenStepPin, -- I/O 19 PIN 3 PIN 2 X2 Step
IOPortTag & x"00" & NullTag & NullPin, -- I/O 20 PIN 4 PIN 15 just GPIO
IOPortTag & x"04" & StepGenTag & StepGenDirPin, -- I/O 21 PIN 5 PIN 3 X2 Dir
IOPortTag & x"00" & NullTag & NullPin, -- I/O 22 PIN 6 PIN 16 just GPIO
IOPortTag & x"05" & StepGenTag & StepGenStepPin, -- I/O 23 PIN 7 PIN 4 Y2 Step
IOPortTag & x"00" & NullTag & NullPin, -- I/O 24 PIN 8 PIN 17 just GPIO
IOPortTag & x"05" & StepGenTag & StepGenDirPin, -- I/O 25 PIN 9 PIN 5 Y2 Dir
IOPortTag & x"06" & StepGenTag & StepGenStepPin, -- I/O 26 PIN 11 PIN 6 Z2 Step
IOPortTag & x"06" & StepGenTag & StepGenDirPin, -- I/O 27 PIN 13 PIN 7 Z2 Dir
IOPortTag & x"07" & StepGenTag & StepGenStepPin, -- I/O 28 PIN 15 PIN 8 A2 Step
IOPortTag & x"07" & StepGenTag & StepGenDirPin, -- I/O 29 PIN 17 PIN 9 A2 Dir
IOPortTag & x"00" & NullTag & NullPin, -- I/O 30 PIN 19 PIN 10 just GPIO
IOPortTag & x"00" & NullTag & NullPin, -- I/O 31 PIN 21 PIN 11 just GPIO
IOPortTag & x"00" & NullTag & NullPin, -- I/O 32 PIN 23 PIN 12 just GPIO
IOPortTag & x"00" & NullTag & NullPin, -- I/O 33 PIN 25 PIN 13 just GPIO
29 Jan 2018 15:50 #105160
I looks like you could use the 5i25_5ABOBx2.bit file
you might try that to see if it changes your power down issue
- eFalegname
29 Jan 2018 16:51 #105162
by eFalegname
I flashed the 6i25 with the 5i25_5ABOBx2.bit. Now when I turn on the PC the red led flashes 1 time and the PC turn off for 3-4 seconds, then my PC turns on by itself and mesa card flash 1 time again, after booting I realize that the file is been replaced again for the previous one (I lose my pin pwm)
29 Jan 2018 17:08 #105164
Are you using Pathpilot? nothing can change the loaded firmware unless its a startup script like pathpilot uses if it does not like the loaded firmware...
Time to create page: 1.057 seconds
