SSI absolute encoders and analog servos
10 years 2 months ago #79060 by andypugh
Replied by andypugh on topic SSI absolute encoders and analog servos
terkaa wrote: Also there is a small typo with SSI pins. It says positon where should be position. ie pin positon.position
A typo in the docs or a typo in your HAL file?
10 years 2 months ago - 10 years 2 months ago #79061 by terkaa
Replied by terkaa on topic SSI absolute encoders and analog servos
Typo in pins of SSI+sserial firmware. This is halcmd show pins output:
2 float OUT 1.118481e+07 hm2_5i25.0.ssi.00.positon.position
12 s32 OUT 11184810 hm2_5i25.0.ssi.00.positon.rawcounts
12 bit I/O FALSE hm2_5i25.0.ssi.00.positon.reset
All three lines have positon.xxxxx
Tero
Last edit: 10 years 2 months ago by terkaa.
10 years 2 months ago #79066 by PCW
Replied by PCW on topic SSI absolute encoders and analog servos
Maybe the hal pins use the name in the ssi_chan_0=something config line
so if that's misspelled all the position pins will be
( there are no positon strings in the hostmot2 driver )
10 years 2 months ago #79067 by andypugh
terkaa wrote: Typo in pins of SSI+sserial firmware. This is halcmd show pins output:
github.com/LinuxCNC/linuxcnc/search?utf8=%E2%9C%93&q=positon
I don't see it there. The ssi pins are pretty much _all_ given names from the HAL file.
What does your "loadrt hm2_pci" HAL line say?
10 years 2 months ago #79068 by terkaa
Yes you are correct it was my typo in the config line I had positon%24. Sorry about that. Now corrected. Here is output of halcmd show param
12 float RW 400 hm2_5i25.0.ssi.00.frequency-khz
12 u32 RW 0x00000100 hm2_5i25.0.ssi.00.positon.counts-per-rev
12 float RW 1 hm2_5i25.0.ssi.00.positon.scale
12 u32 RW 0x00000001 hm2_5i25.0.ssi.00.timer-number
So that is timer-number
Tero
10 years 2 months ago #79241 by terkaa
Ok we have a reading. It seems encoder output is 32 bit binary. Some pics:
[IMG
[IMG
Reading seems to increase or decrease steadliy when scale head is moved in either direction. Thank you very much for help.
Tero
Moderators: PCW, jmelson
Time to create page: 0.183 seconds
