SSI absolute encoders and analog servos
10 years 2 months ago #79395 by terkaa
Replied by terkaa on topic SSI absolute encoders and analog servos
Recently updated to 2.7.6
10 years 2 months ago #79397 by terkaa
Also found this from terminal:
Message from syslogd@Cinci at Aug 25 08:54:14 ...
kernel:[ 545.868700] NMI: PCI system error (SERR) for reason a1 on CPU 0.
kernel:[ 545.868707] Dazed and confused, but trying to continue
Related?
10 years 2 months ago #79403 by PCW
Replied by PCW on topic SSI absolute encoders and analog servos
Might be related, sounds like a PC hardware error of some kind
10 years 2 months ago #79404 by terkaa
I believe it is a bug within graphics adapter firmware. Those errors were present before this timing warning
Tero
10 years 2 months ago #79407 by terkaa
How can I debug this issue more to find out actual cause for timing warning.
10 years 2 months ago #79433 by PCW
I would try to eliminate the NMI, this is not going to be good for real time performance
Also, as I mentioned, you could monitor (via halscope for example) the dpll error so see if it loses sync do to
some real time issue with your system
Moderators: PCW, jmelson
