SSI absolute encoders and analog servos
10 years 6 days ago #82073 by terkaa
Replied by terkaa on topic SSI absolute encoders and analog servos
Better?
[IMG
I tried to adjust it a bit by setp hm2_5i25.0.dpll.base-frequency-khz 1.008 and it moved signal closer to zero but for some reason gave data transmission error.
Tero
10 years 6 days ago #82074 by terkaa
Ok 1.007 gives best result:
[IMG
But we still get :
[IMG
Tero
10 years 6 days ago #82083 by PCW
Replied by PCW on topic SSI absolute encoders and analog servos
Did you set the frequency in the hal file?
Do the errors only come once?
10 years 6 days ago #82086 by terkaa
Did you not see halscope pics I posted? Photobucket has been slow today. Yes I did with setp hm2_5i25.0.dpll.base-frequency-khz 1.007 I was able to get phase.error quite close to zero. Yes this warning comes only once. See pics above pls.
Tero
10 years 6 days ago #82087 by PCW
Yes i saw the pictures and assumed you use setp to set the base rate
my question was whether this was done in the hal file at startup or via
a halcmd later
10 years 6 days ago #82091 by terkaa
In HAL file almost at the top. Before setting timers for SSI.
Tero
Moderators: PCW, jmelson
