SSI absolute encoders and analog servos
10 years 1 week ago #82044 by PCW
Replied by PCW on topic SSI absolute encoders and analog servos
looks basically OK
As a side note all the SSI encoders ( if they have identical timing ) should be using the same timer
this wont cause any issues but wastes timers
What is the time scale of the DPLL phase error plot?
If I had to guess the problem I would guess that the hosts PCI clock is not 33.3 MHz so the DPLL base frequency is not correct
10 years 1 week ago #82045 by terkaa
Replied by terkaa on topic SSI absolute encoders and analog servos
Oh, ok I will change this. I will check time scale tomorrow. How can I check actual PCI clock of system?
Tero
10 years 1 week ago #82046 by terkaa
4000 samples at 1kHz
Tero
10 years 1 week ago #82047 by PCW
OK but what i really need is halscopes time/division setting
10 years 1 week ago #82053 by terkaa
10 years 6 days ago #82055 by PCW
OK so about 10 Hz (a 1% error)
This does expose a weakness of the DPLL for the 5I25 and 5I24 that depend on the PCI clock for timing
Some Motherboards do not set the PCI clock close enough to 33.33 MHz to allow the DPLL to lock
Ultimately this should probably be fixed in the hm2 driver by a clock calibration phase, but for now
to use that motherboard you will have to tweak the DPLL base frequency
I would try +1% and -1% first
setp hm2_5i25.0.dpll.base-frequency-khz 1.01
and
setp hm2_5i25.0.dpll.base-frequency-khz 0.99
and see if either gives you a lock
once you have a lock, you can tweak the number to get the smallest absolute offset
of the average phase error
Moderators: PCW, jmelson
Time to create page: 0.161 seconds
