- Thank you received: 5334
SSI absolute encoders and analog servos
10 years 6 days ago #82100
Replied by PCW on topic SSI absolute encoders and analog servos
Do you get an error if you don't set the SSI timer channels?
If not, its probably possible to set the timer channels after the DPLL has stabilized
- terkaa
- Thank you received: 3
10 years 6 days ago #82109
by terkaa
Replied by terkaa on topic SSI absolute encoders and analog servos
I will check this tomorrow. If I do not get any, how do I set timers on after DPLL has stabilized?
Tero
Tero
10 years 5 days ago #82112
For a test you can do it with a halcmd
it may be that it could be done in the postgui hal file
In the mean time I will look for a solution for DPLL configs where
the base clock is off by a significant amount
( This is not an issue with PCIE or Ethernet, only some PCI cards + some Motherboards )
- terkaa
10 years 5 days ago #82136
by terkaa
Ok I did comment out lines setp hm2_5i25.0.ssi.0n.timer-number 4 from HAL. Then I started control. Waited for at least 5 mins. But right after using halcmd setp hm2_5i25.0.ssi.01.timer-number 4. I get same warning....
Tero
Tero
10 years 5 days ago #82142
There may be more going on here than just the wrong base frequency
What kind of latency do you get on that system?
I ask because your DPLL error plot even when adjusted, looks quite bad for a PCI system
For example here is a Ethernet system which should typically have worse latency but is much much better
than your system:
If i get a chance i will try and duplicate your issue here later today and see if I can come up with a workaround
than your system:
10 years 4 days ago #82162
I did some testing and the standard DPLL has a lock-in range of about +-0.75% at 1 KHz
normally this is OK but the PCI clock is just about that far off on your Motherboard
I made a quick test with variant DPLL tuning that allows about a 3% lock in range
so if you remind me what bitfile name you have, i can make a wide lock-in range version
for you to test. The variant also incorporates a integral term in the DPLL so small timebase offsets
are zeroed
are zeroed
Time to create page: 0.188 seconds
