SSI absolute encoders and analog servos
10 years 2 months ago #79045 by terkaa
Replied by terkaa on topic SSI absolute encoders and analog servos
Nope it did not work either.
Tero
10 years 2 months ago #79049 by andypugh
Replied by andypugh on topic SSI absolute encoders and analog servos
I just realised... This is an SSI pin.
The SSI pin names depend entirely on the config string passed to the module.
In other words, you only get the pins you ask for. Why do you think that there should be a timer-number pin?
10 years 2 months ago #79052 by PCW
Replied by PCW on topic SSI absolute encoders and analog servos
Its a parameter:
(s32 r/w) hm2_XiXX.N.ssi.MM.timer-num
This parameter allocates the SSI module to a specific
hm2dpll timer instance. This pin is only of use in
firmwares which contain a hm2dpll function and will
default to 1 in cases where there is such a function, and
0 if there is not. The pin can be used to disable reads
of the encoder, by setting to a nonexistent timer number,
or to 0.
10 years 2 months ago #79054 by terkaa
So this line should be "setp hm2_5i25.0.ssi.00.timer-number 1"
10 years 2 months ago #79057 by PCW
The manual page says timer-num
10 years 2 months ago #79059 by terkaa
Ok,
Does work, but I will check if there is also timer-num parameter. Also there is a small typo with SSI pins. It says positon where should be position. ie pin positon.position
Tero
Moderators: PCW, jmelson
Time to create page: 0.387 seconds
