SSI absolute encoders and analog servos
10 years 5 months ago #74164
Replied by andypugh on topic SSI absolute encoders and analog servos
The smart-serial cards need to be powered-up to be detected. You should see some LED flickering on the cards as hm2_pci loads too.
What firmware did you flash the 5i25 with?
- terkaa
- Thank you received: 3
10 years 5 months ago #74166
by terkaa
Replied by terkaa on topic SSI absolute encoders and analog servos
Yes adding field power did the trick, thank you. It was flashed with
"freeby.mesanet.com/ssi_ss.zip
Has bit and added source files for a 5i25/6i25 8xSSI+8xSSerial config for a 1 or 2 7I74s
(4 SSI+4SSerial per 7I74 SSI channels first on 7I74 (0..3), SSerial last (4..7)) "
Still would like to know correct config for it to place in INI file. For 4 SSI encoders + 4 sserial cards.
10 years 5 months ago #74167
The config string for hm2_pci is normally only needed if you want to turn off modules to make the pins usable as GPIO or to set the software data mode of some smart-serial devices.
I can't remember what the SSI driver does with no config string. You should probably try it with one to see if that makes the SSI pins show up.
The format of the config string is described here:
linuxcnc.org/docs/2.7/html/man/man9/hostmot2.9.html#Synchronous Serial Interface (SSI)
terkaa wrote: (4 SSI+4SSerial per 7I74 SSI channels first on 7I74 (0..3), SSerial last (4..7)) "
10 years 5 months ago #74168
Can you paste the pin-description bit from dmesg too? That might be useful reference info.
[code]
sudo dmesg -c
halrun
loadrt hostmot2
loadrt hm2_pci
exit
dmesg[/quote]
Ignore the output of the first dmesg, and paste the output of the second one.
[code]
sudo dmesg -c
halrun
loadrt hostmot2
loadrt hm2_pci
exit
dmesg[/quote]
- terkaa
10 years 4 months ago - 10 years 4 months ago #75746
by terkaa
Last edit: 10 years 4 months ago by terkaa.
- terkaa
10 years 4 months ago #75748
by terkaa
Yes it was me. I had ssi_encoders statement on config line and that disabled all ports except no 7.
Tero
Tero
Time to create page: 1.416 seconds
