SSI absolute encoders and analog servos
10 years 6 months ago #72921 by andypugh
Replied by andypugh on topic SSI absolute encoders and analog servos
There is not (as far as I know) a real-time Modbus interface to LinuxCNC HAL.
And encoder feedback is one place where you really want realtime.
10 years 6 months ago - 10 years 6 months ago #72930 by terkaa
Replied by terkaa on topic SSI absolute encoders and analog servos
Ok so I will stick with original plan. Is there a bit file for 5i25 + 7i74 + 7i83 combo? I installed LinuxCNC on this laptop and downloaded 5i25 firmware files from Mesanet. But I cant see how to make this kind of configuration. Also selecting config with 7i74 gives me following error:
PNCconf encountered an error. The following information may be useful in troubleshooting:
File "/usr/bin/pncconf", line 2891, in on_mesa_component_value_changed
self.set_mesa_options(boardnum,title,firmware,numofpwmgens,numoftppwmgens,numofstepgens,numofencoders,numofsserialports,numofsserialchannels)
File "/usr/bin/pncconf", line 2999, in set_mesa_options
numofpwmgens,numoftppwmgens,numofstepgens,None,numofsserialports,numofsserialchannels,False)
File "/usr/bin/pncconf", line 3356, in firmware_to_widgets
self.widgets[p].set_model(self.d)
File "/usr/bin/pncconf", line 1127, in __getitem__
return getattr(self, item)
AttributeError: Data instance has no attribute '_sserial6_signalfilter'
Last edit: 10 years 6 months ago by terkaa.
10 years 6 months ago #72950 by andypugh
If you post that last message to the Pncconf section hopefully Chris will see it.
10 years 6 months ago #72984 by PCW
Replied by PCW on topic SSI absolute encoders and analog servos
freeby.mesanet.com/ssi_ss.zip
Has bit and added source files for a 5i25/6i25 8xSSI+8xSSerial config for a 1 or 2 7I74s
(4 SSI+4SSerial per 7I74 SSI channels first on 7I74 (0..3), SSerial last (4..7))
10 years 6 months ago - 10 years 6 months ago #72985 by terkaa
Ok this is what I need. Does this work with Pncconf or does that need XML file also? I need to make an order for cards asap :) Thank you
Tero
10 years 6 months ago #72986 by PCW
I dont think there's much hope of this working with pncconf
Moderators: PCW, jmelson
Time to create page: 0.212 seconds
