The inverse pulses would be generated by a line-driver, not by the encoder itself.fons wrote: thx for the quick reaction i can go work on mine project in thise way prepairing a 180puls enconder is ABZ enough or do i need also the inverve pulse-A-B-Z
why an unloaded steppermotor stall at higher speed ?
Nothing should connect to TB1 pin 5 (VIN)
VFIELD (TB1 pins 1..4) is where +24V power goes
The isolated field I/O on the 7I76E runs from a switching power supply that can be powered by field power or a separate supply (VIN) with ground common with field power.Normally the 7I76E will be powered with field power and an on card jumper, W1 allows VIN to be connected to field power. If you wish to use a single power supply for the 7I76Es field outputs and field logic power, W1 should be placed in the left hand position. This connects field power to VIN. If you wish to use a separate supply for VIN, W1 Should be placed in the right hand position.
