My 7i76e Connection Sheet
5 years 6 months ago #205525 by PCW
Replied by PCW on topic My 7i76e Connection Sheet
A resistor would be needed only if the optocoupler common was ground
if the optocoupler can supply 24V to an input an pullup resistor is not needed
2K 1/2 W should be fine if a pullup is needed
A flipflop component with its clock driven by the alarm signal
(and data pin tied to '1') can detect the alarm signal
A better choice might be the oneshot component set for a bit over 1/2 second
The oneshot component has the advantage that it can be set up to trigger
on both edges of the alarm signal and may not require resetting
  • BeagleBrainz
  • New Member
  • New Member
5 years 6 months ago #205539 by BeagleBrainz
Replied by BeagleBrainz on topic My 7i76e Connection Sheet
The optos are connected internally to a common ground.
I’ll look into the one shot as well.
Once again thanks for your help.
5 years 1 month ago #220368 by fons
Replied by fons on topic My 7i76e Connection Sheet
the mesa 7i76 e had 2 mpg inputs  can you add 2 more  ?
5 years 1 month ago #220371 by PCW
More could be added to either of the parallel expansion ports
(or a 7I73 could be added to the serial expansion port, adding 4 more MPG channels)
5 years 1 month ago - 5 years 1 month ago #220821 by fons
can i find somewhere an example how to setup a gearbox in the hal file
i have 4 speed settings combined 16 gears
28 35 45 56 70 90 112 140 180 224 280 355 450 560 700 900 rpm
i will us use a vfd to control the motor 1450rpm 7.5kw
Last edit: 5 years 1 month ago by fons.
4 years 1 month ago #252556 by Ironmadnes
Great, thanks a lot for sharing this!
Moderators: PCW, jmelson
Time to create page: 0.359 seconds
