My 7i76e Connection Sheet
5 years 11 months ago #189077 by PCW
Replied by PCW on topic My 7i76e Connection Sheet
In the hal line that starts with:
loadrt hm2_eth
You must change the sserial port token to sserial_port_0=20xxxx
The original hal line was omitted from your first post but it probably has
sserial_port_0=00xxxx
5 years 11 months ago #189158 by fons
Replied by fons on topic My 7i76e Connection Sheet
pcw you had it all right i made a typo and that was the reason why i couldn't get it working
rodw I used your post from 16 Mar 2018 00:00 for the axle selection and indeed I got that going now
I am very grateful to both of you for the patience you have shown
now we are going to start with the next step the tool length and the position of the workpiece
5 years 11 months ago #189161 by fons
mine test setup
5 years 11 months ago #189265 by fons
what can go wrong yesterday i had a working linuxcnc with jog and axil selection
today i just change the value of the z-axis puls/unit ,speed and accelreration and in got again an error from the custom.hal
Debug file information:
Note: Using POSIX realtime
./custom.hal:81: Pin 'hm2_7i76e.0.7i76.0.0.enc0.count' does not exist
4978
when i create a new installation 3 axis that work fin . when i add the custom hal this error appears again where do i have to search ?
5 years 11 months ago #189268 by tommylight
You have to set the 7i76E to mode 2 in the main hal file,
loadrt hm2_eth board_ip="192.168.1.121" config="num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=20xxxx"
Notice the last part with 20xxxx, you have it as 00xxxx.
Not sure about the number of encoders though, but give it a try.
5 years 11 months ago #189273 by fons
thx for the quick replay
yes thats the solution why do it change when i configer the value of axis ?
Moderators: PCW, jmelson
Time to create page: 0.334 seconds
