My 7i76e Connection Sheet
6 years 1 month ago #183811 by fons
Replied by fons on topic My 7i76e Connection Sheet
i total new with mesa cart , buy a 7i76e setup the linuxcnc software in a laptop hp envy i7 ,
setup the network adaptor of the pc manual tot ip 10.10.10.1 , change the w3 switch to above (leave the other switches on standaert setting) , network cable direct from pc to the mesa cart , put 5v on conector p3
when i ping 10.10.10.10 the result is a time out
what do i have to do more ?
6 years 1 month ago #183814 by tommylight
More info
What Linux?
What LinuxCNC version?
Does the LED's on the Mesa board light? Any of them ?
Did you set up the network according to tutorials?
forum.linuxcnc.org/27-driver-boards/3559...ethernet-mesa-boards
  • BeagleBrainz
  • New Member
  • New Member
6 years 1 month ago #183816 by BeagleBrainz
Replied by BeagleBrainz on topic My 7i76e Connection Sheet
Are you using a straight thru cable or a cross over cable ?
6 years 1 month ago #183949 by fons
first problem is solved when i set the networksetting using the graphic screen it wil not react propper do just te same in comand line it acsept correct
i'm abble to ping the adress 10.10.10.10 get an answer in .06msec
when i send the command "sudo mesaflach --device 7i76e --readhmid" i got the answer "no 7i76e board found" same with "sudo mesaflach --device 7i76e addr 10.10.10.10 --readhmid"
do i miss some driver i use linuxcnc 2.7
6 years 1 month ago #183955 by tommylight
fons wrote: i'm abble to ping the adress 10.10.10.10 get an answer in .06msec
Seems like you are pinging the PC not the Mesa board.
The PC address should be set to something like 10.10.10.100, not 10.10.10.10.
6 years 1 month ago #183957 by fons
when i ping loopbach the pc i got 0.015msec
i set the adress of the pc to 10.10.10.11
i install the linuxcnc-2.7.14-wheezy.iso on a pc that is only for cnc using
Moderators: PCW, jmelson
Time to create page: 0.144 seconds
