- Thank you received: 10
I do that for plasma cutters to limit imterferences, namely every limit switch and float switch has a relay power by 24V, the contacts just short the inputsbto the ground. Normaly closed limit switches, so whatever breaks betveen them, i get an error.Gommiswald wrote: And lastly: Why not switch a relay between the inductive proximity switches and the 7I76E connections? 24V switched by the FieldPower connection via a relay? There would be the whole thing with the resistance simply fall away?
