My 7i76e Connection Sheet
8 years 10 months ago #103363 by rodw
Replied by rodw on topic My 7i76e Connection Sheet
Daniel, thats a really good idea and you would probably get more people to look at your question if you raised a seperate thread.
I think it would be pretty easy to do. The 7i76e has analog voltage pins that return the voltage read. Say you put a potentiometer on the field power (I will assume 24 volts), you would need to pick a voltage to represent zero override (say 12 volts). you could use mult2 (with the inverse of 12) to set a 0% to 200% range (0.0-2.0) If say you wanted to limit the control to only allow say 80% to 120% , you could use the scale component to achieve this.
8 years 10 months ago #103502 by andypugh
Replied by andypugh on topic My 7i76e Connection Sheet
Check the manual, some analogue inputs on some boards (7i64 for example) are 3.3V max.
8 years 10 months ago #103503 by rodw
andypugh wrote: Check the manual, some analogue inputs on some boards (7i64 for example) are 3.3V max.
The 7i76e analog inputs discussed on this thread are 8 bit, 36.3 volts full scale with an accuracy of +-5%
8 years 10 months ago - 8 years 10 months ago #103851 by +Jan+
Replied by +Jan+ on topic My 7i76e Connection Sheet
Hello,
I think this might fit here, some days ago I made labels for the clamping brackets of the 7i76:
I attach the pdf and dxf file. I`ve printed them sticked them on doublesided tape.
Best wishes
Jan
Your browser does not support embedded PDFs. Please download the file here: Download PDF.
File Name: 171217_mes...2-30.dxf
File Size:279.14 KB
Last edit: 8 years 10 months ago by +Jan+.
The following user(s) said Thank You: phillc54, tecno, snoozer77, silopolis, The_wolf_of_walmart, palmac, Flyer007 and 2 other people also said thanks.
8 years 10 months ago #103852 by tecno
Replied by tecno on topic My 7i76e Connection Sheet
Nice job Jan
8 years 10 months ago #103854 by Moronicsmurf
Very nice, this will help a bundle. =)
Moderators: PCW, jmelson
Time to create page: 0.081 seconds
