I'm confused about TB3 power connections. The Mesa manual says:
"CABLE 5V POWER
The 7I76 can get its 5V encoder, step/dir and serial interface power from the host interface card if desired. W2 determines if the 7I76 gets this 5V power from the host FPGA card. If W2 is in the left hand position, host cable power is used. If W2 is in the right hand position, 5V power must be supplied to the 7I76 via TB3. This option must be set to match the cable power option of the host FPGA card. If the FPGA card supplies 5V, W2 must be in the left hand position. If the FPGA card does not supply 5V, W2 must be in the right hand position. Never apply external 5V power to the 7I76's TB3 connector when W2 is in the left hand position or you may damage the 7I76, FPGA card, PC, or connecting cable."
Later on (page 6), the terminal idents show "+5V supply power" on pin 22.
Strikes me that I'd be brave or foolhardy to decide that the above means I should apply 24V to pin 22, yet Norbert's connection sheet shows just that. Perhaps I've missed something here but the manual is commendably brief.
I've got the W2 header set to take power from the 5i25 but I'm still confused. I suppose I could see what happens if I swap it across but with the price of the 7i76 that doesn't seem the right approach. Is there a regulator between pin 22 and the 5V node? Can I safely apply 24V to pin 22?
