Hi Rod, Thank you very much! That helps a lot!
You are so extremely helpful!
I got some indicator lights working, like "x and z is homed" and "E-stop is active".
The simple code:
# Home
loadrt and2 count=4
addf and2.3 servo-thread
# HALUI signals
net x-is-homed <= halui.joint.0.is-homed
net z-is-homed <= halui.joint.2.is-homed
net x-is-homed => and2.3.in0
net z-is-homed => and2.3.in1
net is-homed <= and2.3.out
# T5.17 = OUTUT8
net is-homed => hm2_7i76e.0.7i76.0.0.output-08
# ESTOP
net estop-activated <= halui.estop.is-activated
net estop-activated => hm2_7i76e.0.7i76.0.0.output-09
But I wonder what useful knobs and indicators could be for the latte.
I've got:
- on/off switch (main power)
- estop knob (not yet in the hal code)
- Two MPGs
- Rotary switch, same as Rod's, for step size per click of the MPG: 1.0 / 0.1 / 0.01 / 0.0
- indicator homed (green)
- indicator estop active (red)
- a knob for the spindle speed (override or just direct to the motor driver, I need to figure, or select it with a switch)
- a knob for spindle rev / on / fwd (may do that later on in software)
Note the screen is not a touch screen, so physical buttons are preferred.
But what is handy to have on a lathe?
Maybe somebody knows?
Pictures of front panels may also help... If I know what it means
Note I'm not the one who are going to use it at first, but just to make it working with the help the friendly people over here!
Team work, let's say!
And I saw these lights, which may be nice to mount on it:
www.aliexpress.com/item/LED-Desk-Lamp-wi...ook/32771576320.html
Could that be handy?
The initial user is 65+, so good light is a plus, I think...
I'm going to my friends over there, and am not able to read the poit here and answer tonight.
But I will jump in tomorrow, again.
Thank you all in advance!!!!
Best regards,
Jack.
