Mesa 7i76e - Joint 0/2 following error
9 years 3 months ago #96482 by andypugh
You might want a coolant on/off/auto three-position switch too (Auto means that it is controlled by G-code, the other positions are overrides). Similarly for the spindle brake if one is fitted.
The following user(s) said Thank You: JackBerkhout
9 years 2 months ago - 9 years 2 months ago #97419 by JackBerkhout
The HP Compaq DC9700 is still running fine, for a week, without any errors.
I guess I'm lucky with it (I actually got two of these).
Last edit: 9 years 2 months ago by JackBerkhout.
9 years 2 months ago #97421 by JackBerkhout
Hi Tecno, homing is working.
I will combine the switch with the end switch on that side, as it is a bit cumbersome to mount many switches.
9 years 2 months ago - 9 years 2 months ago #97443 by tecno
Good that you got it working.
On my lathe I only have 1 switch on each axis and use a rail with adjustable positions to activate the switch with roller top.
Z-axis switch is mounted on carriage and nocks are fixed, on X axis switch is fixed and rail with nocks is moving.
Last edit: 9 years 2 months ago by tecno.
Moderators: PCW, jmelson
Time to create page: 0.268 seconds
