Mesa 7i76e - Joint 0/2 following error
9 years 3 months ago #96159 by andypugh
Unfortunately, "more powerful" doesn't always mean "lower latency"
I don't have a 7i76E so can't give any specific recommendations, though.
The following user(s) said Thank You: JackBerkhout
9 years 3 months ago #96162 by PCW
Before you give up on your current CPU, What OS/ kernel are you using?
(uname -a will print the kernel version)
If you are using the years old 3.2 Preempt-RT kernel you may do better with a newer kernel
(Trying the new Debian Stretch ISO + 4.9 Preempt-RT kernel is at least worth a try)
www.linuxcnc.org/testing-stretch-rtpreempt/
9 years 3 months ago #96166 by JackBerkhout
Hi Andy,
true!
Hi PCW,
uname -a
Linux LinuxCNC 3.2.0-4-rt-686-pae #1 SMP PREEMPT RT Debian 3.2.89-2 i686 GNU/Linux
Thank you for checking!
Regards,
Jack.
9 years 3 months ago #96176 by rodw
I would try what PCW suggests. If you buy new hardware, you probably will need to use a more modern build of Linux to get the driver support so you might as well practice on your existing hardware!
I have not got any direct experience but when I was looking for hardware, Celeron based chipsets were recommended. PCW will know more but something like a N3160 cpu which will save you some money. Your Chinese friends will have one....
9 years 3 months ago #96186 by JackBerkhout
Hi Rod,
I found this refurbished PC, not expensive, but it may not be a Celeron.
www.alpha-shop.nl/hp-dc7900-core2duo-250gb-4gb.html
This was the cheapest, though.
Regards,
Jack.
9 years 3 months ago #96200 by rodw
JackBerkhout wrote: Hi Rod,
Regards,
Jack.
Jack, sorry I can't really advise you on hardware. There are a few Core2's listed here
wiki.linuxcnc.org/cgi-bin/wiki.pl?Latency-Test
Moderators: PCW, jmelson
Time to create page: 0.231 seconds
