7i73 LCD shows rubisch
- Mike_Eitel
- Thank you received: 183
14 Jan 2018 20:45 #104458
by Mike_Eitel
7i73 LCD shows rubisch was created by Mike_Eitel
Hi
I upgraded via synaptics to newest master.
Since then my LCD on the 7i67e/7i73 combo puzzels the screen
It is still the correct text but something goes wrong with the positioning.
Before everything was correct.
Ansonsten idea how to get right again?
- Thank you received: 5335
14 Jan 2018 21:26 #104464
Replied by PCW on topic 7i73 LCD shows rubisch
Unless you need master features, for a production machine I would run the latest 2.7
I don't think there's anyway to backtrack master versions unless you compile from source
- Mike_Eitel
14 Jan 2018 21:41 #104467
by Mike_Eitel
Replied by Mike_Eitel on topic 7i73 LCD shows rubisch
Sorry PCW, but until now everything works find with master.
And I like the concept of separation of joints and axes and other new features.
I do not intend to backtrack, but hope this problem will be fixed sooner or later.
In my eyes there is momentary a bug in the lcd component.
Mike
Mike
14 Jan 2018 21:49 - 14 Jan 2018 21:50 #104469
Unless you had a pretty old version of master, (older than August 2016)
it is not a lcd issue but rather a sserial issue.
Unless someone with that has the same setup so can duplicate the issue backtracks (via git bisect)
to find the commit that broke this it may not be fixed for quite a while
Last edit: 14 Jan 2018 21:50 by PCW.
- newbynobi
- Thank you received: 394
14 Jan 2018 21:50 #104470
by newbynobi
Replied by newbynobi on topic 7i73 LCD shows rubisch
I have the same problem!
7i73 connected to 7i76e,
i thought it is a hardware problem, but it happened also after an update, so it might well be a modification in the code. The display seems to jump around, like having to much signs for one line and a wrong frequency.
Norbert
Norbert
- Mike_Eitel
14 Jan 2018 21:58 #104472
by Mike_Eitel
Thx newbynobi
It's in the code you send me. I'm working in that.
As test i modified to just pure four static letters..
All other data from 7i73 are correct, also the 8 outputs i use are send correct..
Mike
Mike
- Mike_Eitel
20 Jan 2018 21:48 #104754
by Mike_Eitel
Hi Norbert
Is your screen also still srambled, or did you find a reason / solution?
Thx
Mike
Thx
Mike
- newbynobi
22 Jan 2018 16:44 #104851
by newbynobi
Still the same, IMHO it is a SmartSerial bug, I just disconnected mine until I find time to look at it.
Norbert
Norbert
- seb_kuzminsky
- User is blocked
- Thank you received: 13
22 Jan 2018 17:07 #104855
by seb_kuzminsky
Replied by seb_kuzminsky on topic 7i73 LCD shows rubisch
If you're installing debian packages of master from the buildbot, there's a good chance we can discover the "old, working" version number and the "new, broken" version number, which would help us track down and fix the issue. Please post the complete output of this command:
grep 'upgrade linuxcnc' /var/log/dpkg.logPlease Log in or Create an account to join the conversation.
- rene-dev
- Thank you received: 27
22 Jan 2018 17:16 #104856
by rene-dev
Replied by rene-dev on topic 7i73 LCD shows rubisch
It could be related to this: github.com/LinuxCNC/linuxcnc/commit/d92f...1a785a50d33f8cea32c6
try a version before this commit.
Rene
Rene
Time to create page: 0.120 seconds
