7i73 LCD shows rubisch
  • Mike_Eitel
  • Mike_Eitel's Avatar Topic Author
  • Platinum Member
  • Platinum Member
09 Feb 2018 22:46 #105673 by Mike_Eitel
Replied by Mike_Eitel on topic 7i73 LCD shows rubisch
Here the config that Norbert supplied what worked fine on the same display.
File Name: 7i76e_7i73.zip
File Size:220 KB
Have a good night and my biggest thanks for your effort
10 Feb 2018 01:35 #105676 by andypugh
Replied by andypugh on topic 7i73 LCD shows rubisch
I tried your string, it works just as well for me in 2.7.12 and latest Master.
So I don't know where to go from here. I can't really fix a problem that I can't test.
Also, I am away from home again for the next two weeks starting tomorrow morning (Work, this probably annoys me even more than you)
  • Mike_Eitel
  • Platinum Member
  • Platinum Member
10 Feb 2018 08:29 #105694 by Mike_Eitel
Thx a lot
One question? I use 7i76e and i have impression you ,use 5i25. True?
Wish you all the best on your working job. Know the time constraints quite good myself. Original plan was finishing my new verdin Christmas 17.... Hope now to have something in a few month. The lcd is an addon for gmoccapy, want to show dynamic fluteload cuttingspeed etc.
I will try to ask Norbert if his display still has the same behavior like mine.
  • Mike_Eitel
  • Platinum Member
  • Platinum Member
10 Feb 2018 10:43 #105696 by Mike_Eitel
@pcw
Do you think i should try to reflash the 7i76e?
And is there a way to do that for the 7i73 too and would you try that?
Thx Mike
10 Feb 2018 12:11 #105700 by newbynobi
Replied by newbynobi on topic 7i73 LCD shows rubisch
Hallo Andy,
I just tested with your script (modified for 7i76e) on recent master and the display does not stay synchronized, meaning the letters are jumping around.
Then I switched over to 2.7 and the display shows all correct.
Unfortunately I have no other card to check, if this is related to 7i76e connection.
Norbert
  • Mike_Eitel
  • Platinum Member
  • Platinum Member
10 Feb 2018 12:15 #105701 by Mike_Eitel
@Norbert
THX !!!
I already feared that I have to to disassemble my keyboard
10 Feb 2018 12:34 - 10 Feb 2018 12:43 #105703 by newbynobi
OK, next test:
reseted master hard to be 6f0f2cafb89a914ea392c65d2e3dcbe754b1638d
(control.c: honor fractional accels for wheel jogging)
working correct!
reseted hard to d92f69438023d62a66171a785a50d33f8cea32c6
(Smart Serial: Start to enable parameter setting via HAL)
broken!
So IMHO that merge causes the problem.
Andy if you want me to make more checks, I will do that.
If you need a 7i76e for testing, I am able to borrow you one.
Norbert
Note: If I stop the script, the display is holded and I can see, that all letters have moved 1 by right place, So you do not read LinuxCNC but LinuxCNCC, so that might be just a wrong counting in some place.
Last edit: 10 Feb 2018 12:43 by newbynobi.
10 Feb 2018 22:07 #105722 by andypugh
OK. That sounds pretty definitive.
I have an Ethernet Mesa card. I will try with that when I get home (2 weeks)
  • Mike_Eitel
  • Platinum Member
  • Platinum Member
10 Feb 2018 22:12 #105724 by Mike_Eitel
THX Andy
and save travelling.
Mike
26 Feb 2018 20:48 #106565 by andypugh
Still not found time for this. Maybe soon. Sorry
Moderators: PCW, jmelson
Time to create page: 0.169 seconds
