7i73 LCD shows rubisch
- Thank you received: 4654
09 Feb 2018 10:54 - 09 Feb 2018 10:55 #105625
Replied by andypugh on topic 7i73 LCD shows rubisch
There aren't any positioning commands as such.
The LCD HAL component just outputs the format string one character at a time every 1mS. When it gets to the end of the format string it sends a control sequence and starts again.The whole file is here: github.com/LinuxCNC/linuxcnc/blob/master...hal/components/lcd.c
I am not sure that sending the "clear line" character is a good idea.
BUT: None of this has changed for a long time, certainly not between 2.7 and 2.8. If there is a difference there then it has to be in the sserial driver. (And as far as I know none of the process data stuff there has changed at all)
if (inst->f_ptr > inst->pages[*inst->page_num].length){
*inst->out = 0x18; // clear line
inst->buff[0] = 0x1E; // home
inst->buff[1] = 0; //end
inst->c_ptr = 0;
inst->f_ptr = 0;
inst->a_ptr = 0;
return;
}I am not sure that sending the "clear line" character is a good idea.
Last edit: 09 Feb 2018 10:55 by andypugh.
- Mike_Eitel
- Thank you received: 183
09 Feb 2018 13:12 #105630
by Mike_Eitel
Replied by Mike_Eitel on topic 7i73 LCD shows rubisch
Very strange in deed.
For sure that behaviour occured after a synaptic update, but i don't know witch 2.8 version was my oldest working one before.
And Norbert confirmed to have the same problem..
When i read through the github issue and see something like eeprom.. :
@pcw
Is there eventually some "download" for 7i73 to "reset" lcd control firmware?
From my guts feeling i would also suspect something there.
@pcw
- Thank you received: 5325
09 Feb 2018 13:34 #105632
Replied by PCW on topic 7i73 LCD shows rubisch
I dont think the EEPROM data has been to be touched as that would "stick" and you would have issues with
2.7
2.7
09 Feb 2018 13:35 - 09 Feb 2018 13:36 #105633
You need to actively update software on the 7i73 with Mesaflash. It won't happen as part of any update.
Actually, it isn't even Mesaflash, it's a batch file downloadable from Mesa, which uses halrun.
Last edit: 09 Feb 2018 13:36 by andypugh.
09 Feb 2018 13:37 #105634
Has anyone stepped back to 2.7 and proved that the problem goes away?
2.7
- Mike_Eitel
09 Feb 2018 16:04 #105643
by Mike_Eitel
Maybe this helps
Mike
Mike
- Mike_Eitel
09 Feb 2018 19:39 #105654
by Mike_Eitel
One thing more
If I stop the program the scrambling stops and stays constant till i start another lcnc program.
Mike
Mike
09 Feb 2018 20:09 #105655
I think the thing that would help most as Andy says is seeing if its fixed by going back to 2.7
- Mike_Eitel
09 Feb 2018 20:17 #105656
by Mike_Eitel
Hi PCW
Hope you do not ask me to do that.
I'm very happy to have finally a 2.8 running.
And as linux is not easy for me i fear to try going back.
Mike
Mike
09 Feb 2018 21:09 #105657
That's even more baffling, because the smart-serial updates go out every 1mS whether a program is running or not.
One thing more
Mike
Time to create page: 0.446 seconds
