- Thank you received: 5334
7i73 LCD shows rubisch
8 years 8 months ago - 8 years 8 months ago #106667
Replied by PCW on topic 7i73 LCD shows rubisch
Yeah, not only is the data screwy, the write order is backwards so the data may or
may not be sent properly out the serial port
Last edit: 8 years 8 months ago by PCW.
- Mike_Eitel
- Thank you received: 183
8 years 8 months ago #106669
by Mike_Eitel
Replied by Mike_Eitel on topic 7i73 LCD shows rubisch
Ok, i understand that now i will wait.
Still some things to do in my application anyhow. Plus rewiring my old lady to trsnsfer from 7i43 to new 7i76e/7i73 combo.
Thx guys, honestly as one who is in progressional life used to work with lots of suppliers ad programmers. All your support is top knodge !!!!!!
Good night
Mike
Good night
Mike
- rene-dev
- Thank you received: 27
8 years 8 months ago #106812
by rene-dev
Replied by rene-dev on topic 7i73 LCD shows rubisch
can someone please try if this fixes the issue?
github.com/rene-dev/linuxcnc/tree/sserial-race-fix
8 years 7 months ago - 8 years 7 months ago #106815
Replied by andypugh on topic 7i73 LCD shows rubisch
[strike]I was wondering if that was the answer, or whether we needed to keep the setup first and tag a separate DoIt write on the end.[/strike]
I was thinking that the problem was here:
github.com/rene-dev/linuxcnc/blob/4f7110...tmot2/sserial.c#L968
ie, the DoIt is added to the TRAM list by the setup_channel function, not at the end of the setup_remotes function.
(They are called in this sequence here)
github.com/rene-dev/linuxcnc/blob/4f7110...tmot2/sserial.c#L802
Last edit: 8 years 7 months ago by andypugh.
- rene-dev
8 years 7 months ago #106816
by rene-dev
Im not sure I understand what you see as the issue.
My change sets the cs with the do-it after setting the user registers.
that could be an issue if the fpga reads the user register while its written by the driver.
I verified the change of the order by looking at the packets.
now that I think about this issue, that doesnt explain why there is rubbish in the dump.
the data should be there, just in the wrong place.
8 years 7 months ago #106818
It has been a long time since I looked at this, but I thought that the "DoIt" command was in the command register, not the CS register.
Time to create page: 0.348 seconds
