7i73 LCD shows rubisch
8 years 7 months ago #106819 by andypugh
Replied by andypugh on topic 7i73 LCD shows rubisch
Before a DOIT command is written to start a data transfer cycle with the remote
device, the host must write its packed outgoing process data (OPD in table below) to the
interface registers. (The CS register not currently used for outgoing data/control so is not
written)
8 years 7 months ago #106820 by rene-dev
Replied by rene-dev on topic 7i73 LCD shows rubisch
you are right, its in the cmd, not cs register. but the cmd register is also written before the data...
8 years 7 months ago #106821 by andypugh
Yes.
But you are saying that your fix works?
8 years 7 months ago #106822 by rene-dev
so you suggest moving the hm2_sserial_setup_channel last in the sequence?
8 years 7 months ago - 8 years 7 months ago #106823 by rene-dev
I cant test if it works, because I have no issue.
Im only looking at the packets send by hm2_eth.
I do understand that do it should be set after the data is written, thats what im trying to do.
Last edit: 8 years 7 months ago by rene-dev.
8 years 7 months ago #106825 by andypugh
rene-dev wrote: so you suggest moving the hm2_sserial_setup_channel last in the sequence?
That was my plan.
Or, possibly, to add a third function that appends just the command register. I am not clear if it is possible to setup the channel last.
Moderators: PCW, jmelson
Time to create page: 0.574 seconds
