7i73 LCD shows rubisch
7 years 5 months ago #135091 by gaston48
Replied by gaston48 on topic 7i73 LCD shows rubisch
Thank you very much to both of you. Congratulations, it's always good news to locate a bug and fix it.
I will compile the new component and try as much as possible.
I have one last question, what is the point of setting the timing of the servo-thread (1 ms) in the ini file ?
No matter how valuable it is, when I start a session, and I watch the timing of the servothread with halmeter
(fperiod) it always has the same value 0.15ms with my configuration.
just like the time of each loaded rtcomponent .
7 years 5 months ago #135093 by PCW
Replied by PCW on topic 7i73 LCD shows rubisch
The component times are how long they take to execute (in CPU clocks)
Take a look at motion.servo.last-period for the CPU clocks per servo thread invocation
7 years 5 months ago #135139 by gaston48
Perfect, both types of OLED board work well !
5 years 8 months ago #199377 by gaston48
Hello,
the scatering cursor problem appears again with 2.8.1
if you haven't seen my other message, 2.8.1 limits the size of the xml file linked to PyVCP
and thus refuses to start
5 years 8 months ago #200149 by andypugh
Replied by andypugh on topic 7i73 LCD shows rubisch
gaston48 wrote: Hello,
That seems rather odd, as I don't think that the lcd component changed.
github.com/LinuxCNC/linuxcnc/commits/mas...hal/components/lcd.c
Moderators: PCW, jmelson
Time to create page: 0.418 seconds
