7i73 LCD shows rubisch
7 years 5 months ago - 7 years 5 months ago #135011 by gaston48
Replied by gaston48 on topic 7i73 LCD shows rubisch
500 000 ns at 1000 000 ns i have error message smartserial card ...eztc etc 7i73 remote fault with linuxcnc
I repeat again one faith I use the test of andy or it does not fix the servo thread
and I can not load "loadrt motmod etc ..." I can not find an example of syntax
andy test is here:
forum.linuxcnc.org/27-driver-boards/3385...isch?start=20#105606
600 usec sur le Newhaven no 600 nsec
Last edit: 7 years 5 months ago by gaston48.
7 years 5 months ago - 7 years 5 months ago #135018 by PCW
Replied by PCW on topic 7i73 LCD shows rubisch
First I would figure out why you cannot run a 1000000 ns (1 ms ) servo thread
since this is the default servo thread time.
Edit are you sure you tried 1000000 ns not 100000 ns? 100000 ns would definatley fail
The 600 usec max time is listed in the "Table of commands" page 7
Last edit: 7 years 5 months ago by PCW.
7 years 5 months ago - 7 years 5 months ago #135019 by gaston48
it's a little mess in my configurations with card test etc. :)
with a simpler config I mounted the
servo-thread at 3,000,000 ns, no change.
7 years 5 months ago #135020 by PCW
Really dont know, what version of LinuxCNC are you running?
7 years 5 months ago - 7 years 5 months ago #135021 by PCW
Also not sure when the LCD component sends the character to turns off the cursor but if the hal file startup was not in the expected order, this might get lost
7 years 5 months ago #135023 by gaston48
I use 2.7.14 wheezy
thank you for helping Peter :)
on occasion if you could only test the Andy's little program in a terminal without axis
and try to include the "loadrt motmod line" to set the servo-thread
Moderators: PCW, jmelson
Time to create page: 0.300 seconds
