7i73 LCD shows rubisch
  • Mike_Eitel
  • Mike_Eitel's Avatar Topic Author
  • Platinum Member
  • Platinum Member
05 Mar 2018 21:45 #106984 by Mike_Eitel
Replied by Mike_Eitel on topic 7i73 LCD shows rubisch
I still believe in some overwriting stories.
If I understood correctly the lcd hal-sw is writing to something like a "terminal".
Is there a way that this can be done slower? Maybe only 5 times per second?
Or give some pause before writing the next "terminal-screen".
Is by the way always the complete "screen" written or only the difference?
Mike
05 Mar 2018 22:01 - 05 Mar 2018 22:02 #106987 by andypugh
Replied by andypugh on topic 7i73 LCD shows rubisch
I mentioned in an ealier post, the push that destroid the display communication.
That push did not have any effect on the lcd display for me. And as it did not touch the process data part of the driver code, I am at a loss to explain the apparent correlation.
I also found that the display worked just as well for me before and after the push, so I have no way at all to debug the problem.
I _did_ find that for very short display strings ("A|B|C|D") the display was jumpy and bad with _both_ 2.7 and the latest 2.8, so I fixed that hoping to fix the underlying issue.
Can you please explain, why you do change lcd.comp? It might not be clean coded, but the communication problem must be related to something else.
We have also found a long-standing race condition in the sserial driver (also present since at least 2.6. That has been fixed and _also_ has no affect on the LCD on my test system.
I have just reseted the computer from my machine to the working branch and since that step, my displayworks fine!
Which working branch?
Last edit: 05 Mar 2018 22:02 by andypugh.
The following user(s) said Thank You: Mike_Eitel
06 Mar 2018 09:03 #107020 by newbynobi
Replied by newbynobi on topic 7i73 LCD shows rubisch
Hallo Andi,
thanks for explaining the relations.
I just reseted hard to
reseted master hard to be 6f0f2cafb89a914ea392c65d2e3dcbe754b1638d
(control.c: honor fractional accels for wheel jogging)
working correct!
reseted hard to d92f69438023d62a66171a785a50d33f8cea32c6
(Smart Serial: Start to enable parameter setting via HAL)
broken!
Since the reset the display shows all pages correct, if i update to smart serial parameter enable branch, the display shows the broken / jumping letters.
Norbert
06 Mar 2018 13:16 - 06 Mar 2018 13:26 #107031 by andypugh
Hallo Andi,
working correct!
The diff is hard to make sense of as I moved a lot of code to different places, and also accidentally introduced a lot of white-space changes.
github.com/LinuxCNC/linuxcnc/compare/6f0...1656abb536fd4c550fcd
But the critical code is hm2_prepare_tram_write:
github.com/LinuxCNC/linuxcnc/blob/2.7/sr...mot2/sserial.c#L1173
And specifically the part where it writes the stream data in line 1307
The above is as it was in 2.7.
This is the same code in master:
github.com/LinuxCNC/linuxcnc/blob/master...mot2/sserial.c#L1771
Which is, admittedly, now factored out into a function.
The parameter setting code should not even run unless there are changes to parameters in the HAL file. (and even then only if the HAL values are different to those stored in the remote)
Maybe we need to compare ethernet traffic logs to see if there are differences?
Last edit: 06 Mar 2018 13:26 by andypugh. Reason: Wrong URL
06 Mar 2018 16:46 #107043 by andypugh
Norbert: One other thing, can you test the latest Master with the LCD and sserial updates from Sunday?
06 Mar 2018 20:10 #107053 by andypugh
One other experiment to try, can you put the 7i73 into mode 2?
(sserial_port_0=22xxxxxx)
That is "fast display" mode. It makes no difference here (it works perfectly in either mode), but it's an easy experiment.
06 Mar 2018 21:06 - 06 Mar 2018 21:06 #107059 by andypugh
Arggh!! Dewey suggested this and made a fix, and my testing seemed to show that it wasn't the problem...
Try commenting out TWOPASS = true
I finally managed to make a config misbehave, and turning off twopass fixes it.
The problem seems to be that TWOPASS strips \n characters from argument strings.
Try Dewey's new branch, I think it might fix the problem (fixes it here).
github.com/LinuxCNC/linuxcnc/commit/185f...6757e77d9bc983b8fef7
Last edit: 06 Mar 2018 21:06 by andypugh.
07 Mar 2018 17:48 #107084 by andypugh
Dewey's TWOPASS fix is now in Master. Can you test again?
  • Mike_Eitel
  • Platinum Member
  • Platinum Member
07 Mar 2018 18:01 #107085 by Mike_Eitel
For sure, I'm still in train on my way back home, but in ca two hours i should have done the test.
Mike
  • Mike_Eitel
  • Platinum Member
  • Platinum Member
07 Mar 2018 18:55 #107089 by Mike_Eitel
HUREEEY
It's nice as it was before !
Working fine, with only one letter or with filled screen.
Also, Andy, correct till the last letter in the fourth line,
Perfect.
Congrats
THX to ALL.
Moderators: PCWjmelson
Time to create page: 0.137 seconds
