7i73 LCD shows rubisch
04 Mar 2018 15:47 - 04 Mar 2018 15:48 #106910
The lcd HAL component actually communicates with the 7i73 using a different protocol (modelled on an old serial terminal) and then the 7i73 converts those commands to LCD protocol.
You should be able to install this updated version of the lcd component to see if it works better. (I think it does)
Amongst the bug fixes: you can now use a decimal separator of your choice.
Install with
Replied by andypugh on topic 7i73 LCD shows rubisch
Bear in mind that with that code you were communicating directly with the LCD.In my avr programming ( compiler msc bascom) i never saw the problem of the last character.
What I'm absolutely sure is that it worked before absolutely in the way i expected. Norberts screen was shown perfect.
Install with
sudo halcompile --install lcd.c
Last edit: 04 Mar 2018 15:48 by andypugh.
- Mike_Eitel
- Thank you received: 183
04 Mar 2018 16:25 #106911
by Mike_Eitel
Replied by Mike_Eitel on topic 7i73 LCD shows rubisch
Yes it is different, but no, it is not yet good.
the single letters are coming now in all lines plus the sign =
If I use the "big" version of Norbert, it is even worthier, nearly unrecognizable
Have to wait until my tablet finish its unexpected update ( damm !!), then i will post a YouTube
AND many TXt that you take so much efforts !
04 Mar 2018 16:32 #106912
What is the "addf" order in your HAL file?
04 Mar 2018 16:43 #106913
I am wondering if the lcd component needs to be between the read and write functions in the thread sequence (I can't see why it would matter, but...)
Can you download the attached file and then test it with(That is a capital i, not a 1)
You should be able to change pages withetc
halrun -I lcdtest7i76E.halYou should be able to change pages with
setp lcd.00.page_num 2Please Log in or Create an account to join the conversation.
04 Mar 2018 16:59 #106914
- Mike_Eitel
04 Mar 2018 17:20 #106916
by Mike_Eitel
I have to modify to
loadrt hm2_eth board_ip="192.168.1.121" config="sserial_port_0=2100000"
otherwise it does not connect the 7i73.
And strangely it does also not accept writing something like =0x21
But result is not better, still scrambled
- Mike_Eitel
04 Mar 2018 17:22 #106918
by Mike_Eitel
I do use all ports on the 7i73, the 4 analog inputs and all digital in and outputs....No keyboard
- Mike_Eitel
04 Mar 2018 17:39 #106919
by Mike_Eitel
And here my video
04 Mar 2018 18:35 #106920
So, the question has to be "what is different"
First we ought to make sure that your system is using the new version of the LCD component.
"halcmd setp lcd.00.decimal-separator 38" should set all the decimal points to "&" characters if the system has picked up the new version. (That was one of the things I fixed, it wasn't working before)
I am running a 7i80DB connected to a 7i76 connected to a 7i73. This should be really quite similar to your 7i76E
I am _not_ running a full LinuxCNC config, I find it easier to run a smaller system for development work (in fact, the HAL file I already posted) but it is possible that your system has interactions that mine doesn't. (timing is likely to be different)
My 7i73 is using firmware version "C" (show params and it is "swrevision") and LinuxCNC warns me that I should update it.
- Mike_Eitel
04 Mar 2018 18:45 #106921
by Mike_Eitel
I used your file.
Switched of power of pc and mesa before.
Your config explains why I had to change the sserial port.
And for sure your config is a bit slower in throughput.
How can I readout my versions? With mesaflash?
Time to create page: 0.428 seconds
