- Thank you received: 5
7i73 LCD shows rubisch
- gaston48
7 years 5 months ago - 7 years 5 months ago #132639
by gaston48
Replied by gaston48 on topic 7i73 LCD shows rubisch
Hello,
Someone trying to connect an OLED display on a 7i73 ?
I rated 1 LCD display and 1 OLED with Arduino, both are working (but rows permutated on oled )
But on the 7i73 the LCD works but not the OLED
thank you
Linuxcnc 2.7.14 5i20 SVSS4_8
www.lcd-module.com/fileadmin/eng/pdf/doma/olede.pdf
(it's the same as the NHD-0420DZW-AG5)
thank you
Last edit: 7 years 5 months ago by gaston48.
- Thank you received: 5334
7 years 5 months ago #132643
Replied by PCW on topic 7i73 LCD shows rubisch
I wonder if there is some initialization code needed on the OLED display
do any commands like clear screen work?
- gaston48
7 years 5 months ago #132648
by gaston48
thank you PCW,
I do not know, I use Andy's "lcd" there
has no clear screnn instruction.
With arduino, oled and lcd start at power on
I have 2 new 7i73 unit the display is different under the same conditions ?
unit 1300010A
unit 13000168
unit 1300010A
unit 13000168
7 years 5 months ago #132653
Yeah, the display looks random though all 7I73s since 2013 have the same firmware.
Clear screen is ASCII 0x1A
- gaston48
7 years 5 months ago #132665
by gaston48
Ok, I saw that we can send control characters with lcd component "\HH"
I sent 0x1A, 0x0D also, not really effect, it changes the random side.
I forgot to mention that the display is also very animated !
7 years 5 months ago #132668
Yeah maybe the OLED controller is not close enough to the LCD controllers to work properly with the 7I73 signals. We did verify operation with many LCDs
but (relativley) low cost OLEDS were not available at the time we did the testing.
Time to create page: 0.774 seconds
