7i73 LCD shows rubisch
7 years 5 months ago #132715 by PCW
Replied by PCW on topic 7i73 LCD shows rubisch
Just thought of something: how are you powering the OLED?
A LCD would be connected to the 7I73s VEE pin but this wont work with the OLED
Have you tried 5V and 3.3V power from the 7I73?
7 years 5 months ago #132737 by gaston48
Replied by gaston48 on topic 7i73 LCD shows rubisch
By the 5 V of the pin 28 and the GND pin 27. VEE not connected
I suspected the power supply and I checked
with an oscillo the power supply is clean
the funny thing is that when I send a fixed text
the oled sometimes returns an animated light of nignt club :)
An oled display is truly incomparable for a
industrial application: readability in all angles, contrast, time response etc ...
7 years 5 months ago #132739 by PCW
Did you try with 3.3V power?
If the display has CMOS level inputs (as opposed to TTL level)
3.3V signals and 5V power would be marginal
7 years 5 months ago #132741 by gaston48
In my first message, I attached a link from the documentation
" voltage from 3.3 V to 5 V ". The test under arduino is with 5 V
it must not come from there
7 years 5 months ago #132761 by PCW
Are the Arduino signals 5V or 3.3V? (7I73 are 3.3V)
7 years 5 months ago #132764 by gaston48
I just watched on the arduino (pro micro leonardo)
empty : 4.6 V
with load display LCD: 4.1 V
with load display OLED: 3.6 V !!!
it's not 5 V hum hum ...
Moderators: PCW, jmelson
Time to create page: 0.593 seconds
