7i73 LCD shows rubisch
7 years 5 months ago #132981
Replied by andypugh on topic 7i73 LCD shows rubisch
It sounds like the OLD display is marginal for the 5V Arduino.
What are the corresponding voltages when connected to the 7i73?
Are there any jumpers / solar bridges on the display for 3.3V operation?
- Thank you received: 5334
7 years 5 months ago - 7 years 5 months ago #132986
Replied by PCW on topic 7i73 LCD shows rubisch
I'm going to order one of the OLED displays and see If I can duplicate/fix the issue, but it will be a week or two...
Note that going by display specifications, it would not be expected to work with
5V VDD and the 7I73s 3.3V logic levels
(display spec for logic high is 80% of VDD = 4V with 5V VDD)
I will order a display that will work at both 5V and 3.3V to check this out
Last edit: 7 years 5 months ago by PCW.
- gaston48
7 years 5 months ago #132990
by gaston48
Replied by gaston48 on topic 7i73 LCD shows rubisch
Hello to both of you
Andy no jumper for the 3.3 V a link for the
detailed documentation is attached to my first message
oled plugged into the 7i73 the voltage is 4.95V
Thank you PCW, it's not urgent, it's the beginning of a retrofit
I thought at the logical level, but I did not know that the logic level of the 7i73 was 3.3 !!
I will try quickly connect the oled on the 3.3V (P2 pin 29)
thank you,
I will keep you informed
thank you,
- gaston48
7 years 5 months ago #133036
by gaston48
" the devil is in the details "
Yes it was a logical problem
Remains pollution by a blinking cursor (1 Hz) ?
the cursor appears immediately on the power on (up left 0,0)
7 years 5 months ago #133043
I think that there is a control code to turn the cursor off.
(Actually, there is definitely a control code to turn the cursor off, i just don't know if the LCD component allows you to send it)
7 years 5 months ago #133045
github.com/LinuxCNC/linuxcnc/blob/master...omponents/lcd.c#L245
It seems that the driver does attempt to send a cursor-off. Maybe it never worked but LCD displays are too slow to show the cursor?
Time to create page: 0.641 seconds
