7i96 Configuration Tool
6 years 9 months ago #155696 by BigJohnT
I just tested the install on that same OS with no errors.
What does this return?
$PATH
JT
6 years 9 months ago #155722 by COFHAL
cnc@CNC:~$ $PATH
bash: /home/cnc/.local/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games: The file or directory does not exist.
cnc@CNC:~$ $PAT
6 years 9 months ago #155766 by BigJohnT
That looks correct, what happens when you do this in a terminal
mesaflash64 --help
I compiled two versions of mesaflash one 32bit and one 64 bit.
If that works and you can't flash the 7i96 then check your address jumper and try an different Ethernet cable. Sometimes on new cards I have to plug/unplug a couple of times before read works. I always make sure read works before flashing.
JT
6 years 9 months ago #155932 by COFHAL
cnc@CNC:~$ mesaflash64 --help
bash: mesaflash64: order not found
cnc@CNC:~$
6 years 9 months ago #155967 by BigJohnT
For some reason your install failed, uninstall then carefully following the instructions install it again.
JT
6 years 9 months ago #156104 by COFHAL
Now solve the problem, just update the application.
Moderators: PCW, jmelson
Time to create page: 0.337 seconds
