- Thank you received: 5334
PCW wrote: By changing
hm2_7i96.0.gpio.XXX.in
to
hm2_7i96.0.gpio.XXX.in_not
PCW wrote: If you are in doubt about pin or parameter names you can run
halcmd show all > all.txt
(with linuxcnc running) to get a list of all parameters, pins and signals
There are many ways to reverse a step motor direction
hm2_7i95.0.stepgen.00.direction.invert_output
1. swap one motor winding
2. reverse the direction pin wiring (use DIR- instead of DIR+ for example)
3. invert the direction pin in hal ( setp hm2_7i96.0.stepgen.XX.direction.invert_output true )
4. invert the stepgen scale
