Using pktuart with 7i80hd
7 years 4 weeks ago #146993
Replied by andypugh on topic Using pktuart with 7i80hd
You will probably just have to ignore that (printed once) error message.
It is more of a warning than an error.
pktuart access without an llio->read would be very difficult.
- Thank you received: 5334
7 years 4 weeks ago - 7 years 4 weeks ago #146994
Replied by PCW on topic Using pktuart with 7i80hd
I dont think the PktUART has that issue, its the standard UART that has problems with Ethernet (it should probably be re-written so that it gets along with Ethernets packetized read and writes rather than doing random I/O, or just drop it and use the PktUART)
I tested with the mesa_pkt_gyro comp and it does not have any complaints when
run with Ethernet cards (well other that the fact that I complains about no data since I don't have gyro connected)
Last edit: 7 years 4 weeks ago by PCW.
- sneci
7 years 4 weeks ago #147010
by sneci
Replied by sneci on topic Using pktuart with 7i80hd
Yes, there might be something about the ethernet handler. I attached the relevant part of the log.
One interesting thing is that there is no wired loop on the outputs, nevertheless the data arrives on rx.
The other is that it sends all 16 u32 data but after the first byte parser error and 3 bytes are lost.
7 years 4 weeks ago #147070
Have you ever attached your HAL component?
Does the pkt_gyro test work?
linuxcnc.org/docs/2.8/html/man/man9/mesa_pktgyro_test.9.html
7 years 4 weeks ago #147086
Yes it worked on a 7I96 Ethernet card (at least it loaded without serious complaint on a running LinuxCNC system)
It did complain that there was no data which is expected I guess
- sneci
7 years 4 weeks ago #147090
by sneci
No, this was the mesa_uart component.
Time to create page: 0.305 seconds
