Using pktuart with 7i80hd
- sneci
7 years 4 weeks ago #147094
by sneci
Replied by sneci on topic Using pktuart with 7i80hd
Let's wait a bit for the evaluation. I look at it on another machine because latency is very suspicious. AMD A6-7400K 6 core 3.5GHz and had to turn off the watchdog.
This machine was free to play. I attach the hal script.
7 years 4 weeks ago #147095
Replied by andypugh on topic Using pktuart with 7i80hd
Are you using the current, or the fixed, version of mesa_uart?
(and the header says "pktuart"?)
- sneci
7 years 4 weeks ago #147097
by sneci
The header pktuart because this is how I started testing. When the problems came I switched to mesa_uart because I generated the pktuart bitfile. The uart bitfile was made by Peter, sure good
Of course I fixed the mesa_uart name pointer problem. Linuxcnc is from github. I'm attaching the mesa_uart.comp file, please take a look.
- Thank you received: 4153
7 years 4 weeks ago #147110
Replied by rodw on topic 7i80 and uart test
I'm interested in this. Does using pkt_uart still require a bitfile to expose the UART? If so, a freeby for the 7i96 UART based on Peter's *pl.bit file would be something I'd like to play with.
I see PhillC has an Arduino based simulator of a Hypertherm plasma cutter so it would be cool if we could access a plasma cutter using the UART.
- sneci
7 years 4 weeks ago #147125
by sneci
I checked on another machine (Asrock motherboard + i5 cpu) the mentioned two errors are the same.
7 years 4 weeks ago #147133
Mesa_uart is very much just a sample file for an imaginary bit of hardware. It is likely to need to be modified extensively for real hardware.
Time to create page: 0.162 seconds
