Correct, i know this is not how things work on forum. I'm not an expert in linux so this was the most lame and easy way to show it to you... Attached you can find the requested files. I had no idea what kind of input i should use? I guess the wiring doesn't matter? Could you might give me an explanation on the led behavior for the 7i95 card, when i use input 000, should the most right top led lit up? I see more led's on the input card than there are available inputs...
File Name:
7i9pins.txt
File Size:21.22 KB
EDIT: in the meantime i found out i used the wrong inputs. I started working from the top of the card. I/O zero is at the bottom of the card...
So i see hm2_7i95.0.inmux.00.input-12 is high. Should i use this input as the home/limit signal?
EDIT2:
I used the hm2_7i95.0.inmux.00.input-12 input and now the Z axis seems to home fine. But it stays in position above the home sensor, after that i receive the same error: joint 2 on limit switch error. The homing goes over the endstop, retracts back until the endstop is deactivated. Then it returns back on top of the endstop and generates the error. When the machine is in this position i'm unable to do anything with it and i have to move it by hand. I guess i should program a hold off/retract distance or something?
