Mesa 7i95
5 years 9 months ago #195541 by stefcam
Replied by stefcam on topic Mesa 7i95
Hello,
I just got a 7i95 and I'd like to replace 3 stepgen with 3 pwmgen, and use 3 encoders for closed loop.
I'm new to Mesa boards and I'm not sure how to achieve this.
I already took a look at PIN_7I95D_58.vhd, which I think is the file I need to edit but I couldn't find documentation for this.
Can you please tell me where to find docs to learn how to build the bitfile I need? Sorry if this has already been asked but I'm new to this and don't have much time to read the forum.
Thanks a lot.
5 years 9 months ago #195544 by PCW
Replied by PCW on topic Mesa 7i95
Do you want 3 PWM gens replacing 3 stepgens on the 7I95 card?
DO you want PWM and DIR or PWM and ENA?
5 years 9 months ago #195547 by stefcam
  • Yes, in this case would be OK for me to loose 3 stepgens and get 3 pwmgens.
  • I need PWM/DIR.
5 years 9 months ago - 5 years 9 months ago #195580 by PCW
Here is a 7I95 configuration with the last 3 stepgens replaced with PWM/DIR
I have included the changed pinout source as an example if you want to build
/modify it yourself.
(you also need to include the new source file in the top level file to build it)
File Name: 7i95_3pwm.zip
File Size:127.78 KB
Last edit: 5 years 9 months ago by PCW.
The following user(s) said Thank You: andypugh, stefcam, Sergiy_J_S_Automatic
5 years 4 months ago #212058 by Trab
Replied by Trab on topic Mesa 7i95
Hello
i was trying to modify the 7i95 configuration. I just wanted the last step/dir gen to be changed to a pwm/dir
But i have hard times installing Xilinx ISE Design suite. Could anyone maybe change the standard configuration so that the last steg/dir gen is a pwm/dir gen? or give me an alternative programm to edit.
thanks in advance.
5 years 4 months ago #212077 by PCW
7I95 config with PWM/DIR replacing STEP/DIR on last 7I95 STEPGEN connection:
File Name: 7i95_1pwmd...6-14.zip
File Size:122.64 KB
The following user(s) said Thank You: andypugh, Trab
Moderators: PCW, jmelson
Time to create page: 0.193 seconds
