Mesa 7i95
5 years 2 weeks ago #223494 by myval
Replied by myval on topic Mesa 7i95
times are almost half what they were first time
I will try to refetch and report back
5 years 1 week ago #223527 by myval
Did the re-fetch and it just got worse. Now it wont load at all.
First problem was simple to solve even for my little brain and after refetch IPTABLES got root permissions for some reason, I have changed it and the result is in attached report.
File Name: report_2021-10-19.txt
File Size:5.77 KB
5 years 1 week ago #223547 by myval
Got it!
originally I did this
forum.linuxcnc.org/27-driver-boards/3559...ethernet-mesa-boards
but as mentioned in the first line in red do not mix well and I did since I forgot what I did few months ago.
all works as advertised (so far)
Thanks for your help, I will be back for more I am sure :-)
5 years 1 week ago - 5 years 1 week ago #223583 by mittim
Replied by mittim on topic Mesa 7i95
Could anyone share his HAL section for a pwmgen on Pin1 on the PP to run a spindle?
I have a setup with one of those chinese "PWM to 0-10V" modules.
edit:got it.
Last edit: 5 years 1 week ago by mittim.
5 years 1 week ago #224069 by Trab
Replied by Trab on topic Mesa 7i95
Yes, the outputs are isolated switches (0 to 36V, 0 to 2A)
So you can use 5V or 12V or 24V or anything between 0 and 36V
Note that the outputs are not protected against shorted loads
so use a fused or current limited supply. Also the switches
are polarized (if you connect them backwards they will appear
to be always on)
I should add, you can use an Ohmmeter to test the outputs.
Could it be that the ssr´s are on/closed when starting the board?
I think i saw a thread some where how to change it, but i can´t find it anymore.
5 years 1 week ago #224094 by PCW
Replied by PCW on topic Mesa 7i95
The outputs are off at startup, though if you wire them
backwards (reverse polarity) they will appear to be stuck-on.
Moderators: PCW, jmelson
Time to create page: 0.111 seconds
