Mesa 7i95
4 years 9 months ago #231370 by Pro_El
Replied by Pro_El on topic Mesa 7i95
Hello PCW,
I need firmware for 7i95 with all 6 STEP/DIR to be replaced with PWM/DIR. I spend last 7i77 cards, and have only 7i95 at the moment and i need analog..
Thanks in advanced
4 years 9 months ago #231380 by PCW
Replied by PCW on topic Mesa 7i95
File Name: 7i95_pwmd.zip
File Size:104.53 KB
The following user(s) said Thank You: Pro_El
4 years 9 months ago #232640 by Pro_El
Thank you for new firmware for PWM DIR, PCW
I plan to use the basic 7i95 hal and ini you give us for starting editing. Until now i used PncConf but now i am only unclear what i need to change by hand in this files who are made for step and dir to be working like PWM DIR
Or should i use basic7i97 files because i want to drive 7i95 with PWM DIR. What files should be mu starting point and what should i change in PWM sections in the Hal/INI .
Thanks again
4 years 9 months ago #232655 by PCW
You could use the7I97 files as a guide to editing in the PWM output
connections and setup into the 7I95 sample files
Note that if you are using PWM/DIR you should not enable the offset PWM
mode that the 7I97 uses.
4 years 7 months ago #238975 by chienMouille
Replied by chienMouille on topic Mesa 7i95
Sorry I'm totally new here and to all this.
I have a 7i95, which I so far managed to connect to and to jog my servos with, using a pnfconf for a 7i96 and replacing the board names instances.
I'm now trying to connect an MPG to the first counter on the isolated input pins.
I changed this in the HAL file:
# ---jogwheel signals to mesa encoder - x axis MPG---
net x-jog-count <= hm2_7i95.0.inm.00.enc0-count
It's throwing me an error at start up, saying the Pin doesn't exist.
What am i doing wrong?
thanks a lot!
4 years 7 months ago #238980 by chienMouille
ok, found it.
turns out the right spelling is inmux, so:
net x-jog-count <= hm2_7i95.0.inmux.00.enc0-count
Moderators: PCW, jmelson
Time to create page: 0.070 seconds
