Mesa 7i95
5 years 3 weeks ago #222749 by PCW
Replied by PCW on topic Mesa 7i95
Is the machine homed?
You should only be able to jog joints (not axis) before being homed
You can trace motion issues back up the chain by looking (via halshow or halscope)
to see if the commanded joint position is changing as expected
5 years 3 weeks ago #222768 by mittim
Replied by mittim on topic Mesa 7i95
Yes, now it´s moving. Thanks
5 years 3 weeks ago #222772 by mittim
Why do I have to home every single joint before being able to jog and home full axes? Isn´t that dangerous for a gantry type machine, only homing y2 for example?
5 years 3 weeks ago #222774 by PCW
You would be expected to setup the linked joints to home simultaneously
This is done by using a negative sequence number for linked joints:
linuxcnc.org/docs/html/config/ini-homing.html
5 years 3 weeks ago #222778 by mittim
Okay, have to look that up. This is what I´m getting right now before and after homing:
5 years 3 weeks ago #222783 by rodw
Replied by rodw on topic Mesa 7i95
As Peter says, you need HOME_SEQUENCE=N for each joint in your ini.
Joints 1 & 2 (your Y axis) need to be HOME_SEQUENCE=-1
Joint 3 (your Z) is usually HOME_SEQUENCE=0 so it lifts up out of the way at the beginning
All of the rest could be HOME_SEQUENCE=1 so they all home simulteneously or you could continue the sequence to do them in sequence eg use 1,2,3 to set the order you want.
What does it look like after that?
Moderators: PCW, jmelson
Time to create page: 0.266 seconds
