7i76E Ethernet setup
- Mmarmino
05 Dec 2020 17:01 #191138
by Mmarmino
7i76E Ethernet setup was created by Mmarmino
First, i apologize if this has been answered before. i could not find a solution. I am working through the set up of my machine and I am trying to disable the WiCD network manager using the sticky for this. When i input "apt-get install network-manager network-manager-gnome" in the terminal i get:
E: Could not open lock file /var/lib/dpkg/lock-frontend - open (13: Permission denied)
E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are you root?
I'm trying to figure out how to give permission for this folder. Any help is appreciated!
- Thank you received: 7471
05 Dec 2020 18:12 #191140
And do not mess with the permissions.
Replied by tommylight on topic 7i76E Ethernet setup
Should be :"apt-get install network-manager network-manager-gnome" in the terminal i get:
sudo apt-get install network-manager network-manager-gnome
The following user(s) said Thank You: Mmarmino
- Mmarmino
05 Dec 2020 18:26 #191143
by Mmarmino
Replied by Mmarmino on topic 7i76E Ethernet setup
Thanks, i was trying to hurry to get back in here. I had figured out the issue that i didn't have the "sudo". I have since worked through the:
====Network setup for mesa cards: ======
- left click on the network manager on the bottom right side or upper right side where the clock and volume is.
- choose "edit connections"
- double click on the network you want to edit ( usually "wired connection X")
- click on the "IPv4 settings" tab
- choose "manual" on the "method" drop down menu
- click on "add"
- write the address as 10.10.10.11
- never use 10.10.10.1 or 10.10.10.10 for the above
- netmask should be left as is ( usually 8 )
- gateway should always be 10.10.10.1
- additional DNS servers should be 10.10.10.1
From here I'm stuck...do I only imput info on the IPv4 tab? When I close out and click on connection information it says that there are "no valid active connections found".
Save, close, left click on the network manager and click on the "wired connection X", it should take about 3 seconds to reconnect.
Now open a terminal and do Ping 10.10.10.10, you should get normal reply form the Mesa card. If you do not get a reply, double check your settings.
To check the Mesa card configuration, in terminal enter :
mesaflash --device 7i76e --addr 10.10.10.10 --readhmid
- click on "add"
05 Dec 2020 20:40 #191165
Did you remove the WiCD ?
It should be removed/uninstalled.
- Mmarmino
05 Dec 2020 20:58 #191167
by Mmarmino
Yes I uninstalled and went into edit connections and under the IPv4 tab.
- Mmarmino
05 Dec 2020 21:08 #191168
by Mmarmino
I was trying to upload some pictures but everything is exceeding the limits of the file size. But yes I followed the walk-through that was posted but cannot get it to talk to the card via the ethernet cable.
- Mmarmino
05 Dec 2020 21:20 - 05 Dec 2020 21:22 #191170
by Mmarmino
I have the board powered with 24v and if it's any indication I have 2 solid yellow lights on.
Last edit: 05 Dec 2020 21:22 by Mmarmino.
- Thank you received: 5323
05 Dec 2020 21:37 #191172
Replied by PCW on topic 7i76E Ethernet setup
What does the command:
ip a
report?
ip a
report?
- Mmarmino
05 Dec 2020 22:00 #191173
by Mmarmino
this is what i get with "ip a"
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eno1: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
link/ether 1c:69:7a:61:78:12 brd ff:ff:ff:ff:ff:ff
inet 10.10.10.1/24 brd 10.10.10.255 scope global eno1
3: wlp0s20f3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 84:c5:a6:cc:78:1f brd ff:ff:ff:ff:ff:ff
inet 192.168.43.173/24 brd 192.168.43.255 scope global dynamic noprefixroute wlp0s20f3
valid_lft 3448sec preferred_lft 3448sec
inet6 2600:1015:b05c:8786:5512:103a:6029:a73e/64 scope global dynamic noprefixroute
inet6 fe80::3280:98af:2546:f6f7/64 scope link noprefixroute
05 Dec 2020 22:10 #191175
OK that look s OK setup wise
Is the 7I76E connected, powered and set to 10.10.10.10 IP address?
If so you should be able to ping the 7I76E card
The report shows the link as down, is the "automatically connect" checkbox
checked in the general tab of the network manager?
Time to create page: 0.390 seconds
