7i76E Ethernet setup
- Mmarmino
05 Dec 2020 17:04 #191179
by Mmarmino
Replied by Mmarmino on topic 7i76E Ethernet setup
1. Yes under the general tab I have "connect automatically with priority" checked. But priority is set to default zero. I dont know if its important but im also connected via wi-fi for the internet.
2. Under the IPv4 setting tab should anything be in the DSN Servers box?
3. The board is powered with 24v to TB1 and TB3 and the W3 jumper is in the UP position.
4. When powered up I get the three green flashing lights that flash and go off and the two yellow that remain constant.
5. When I ping 10.10.10.10 I just get this repeating:
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data.
From 10.10.10.1 icmp_seq=1 Destination Host Unreachable
- Thank you received: 5337
05 Dec 2020 17:12 #191180
Replied by PCW on topic 7i76E Ethernet setup
Did you power cycle the 7I76E after moving W3?
Do you get link lights on the 7I76E's RJ45 connector?
The following user(s) said Thank You: Mmarmino
- Mmarmino
05 Dec 2020 17:35 #191181
by Mmarmino
The only lights i have on constant is what appears to be CR8 and CR13.
When i power up CR1 blinks yellow, CR2 red, CR4/5/6 green then all off.
And I have a yellow and green lights on the RJ45 connector.
When I perform a flash I get:
mmarmino@debian:~$ mesaflash --device 7i76e --readhmid
No 7I76E board found
05 Dec 2020 17:43 #191183
OK so if you have yellow and green lights on the RJ45, the interface should be "up"
Heres what I get on my Ethernet connection:
2: eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether ec:b1:d7:6c:a2:da brd ff:ff:ff:ff:ff:ff
inet 10.10.10.100/8 brd 10.255.255.255 scope global eno1
valid_lft forever preferred_lft forever
- Mmarmino
05 Dec 2020 17:51 #191185
by Mmarmino
heres what i get...man i don't know.
2: eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether 1c:69:7a:61:78:12 brd ff:ff:ff:ff:ff:ff
inet 10.10.10.1/24 brd 10.10.10.255 scope global eno1
inet6 fe80::1e69:7aff:fe61:7812/64 scope link
05 Dec 2020 17:54 #191186
OK the link is up so that's an improvement
I would disable IPV6
- Mmarmino
05 Dec 2020 18:06 #191187
by Mmarmino
So I think i disabled by selecting Method "ignore" under Ipv6 tab.
heres my ping now:
64 bytes from 10.10.10.10: icmp_seq=1 ttl=64 time=0.420 ms
64 bytes from 10.10.10.10: icmp_seq=2 ttl=64 time=0.441 ms
64 bytes from 10.10.10.10: icmp_seq=3 ttl=64 time=0.437 ms
64 bytes from 10.10.10.10: icmp_seq=4 ttl=64 time=0.443 ms
64 bytes from 10.10.10.10: icmp_seq=5 ttl=64 time=0.443 ms
64 bytes from 10.10.10.10: icmp_seq=6 ttl=64 time=0.442 ms
64 bytes from 10.10.10.10: icmp_seq=7 ttl=64 time=0.400 ms
64 bytes from 10.10.10.10: icmp_seq=8 ttl=64 time=0.433 ms
64 bytes from 10.10.10.10: icmp_seq=9 ttl=64 time=0.440 ms
but...mesaflash --device 7i76e --readhmid
heres my ping now:
05 Dec 2020 18:29 #191190
OK that's expected, you would need:
mesaflash --device 7i76e --addr 10.10.10.10 --readhmid
BTW, the ping times are pretty dismal, what is the host hardware?
- Mmarmino
05 Dec 2020 18:36 #191191
by Mmarmino
I really appreciate all the help. I'm sorry totally new to this. By host hardware do you mean what cpu?
05 Dec 2020 18:54 #191192
Yes CPU type.
Also if you have a Intel Ethernet chip you need to set a driver option
Time to create page: 0.395 seconds
