7i76E Ethernet setup
06 Dec 2020 14:55 #191248 by Mmarmino
Replied by Mmarmino on topic 7i76E Ethernet setup
hmm, maybe due to copy and paste?
I retyped line by line into the interface. Is there more that must be done to the interface file once it has been corrupted?
06 Dec 2020 15:15 #191254 by PCW
Replied by PCW on topic 7i76E Ethernet setup
How did you edit the file? Usually this kind of damage comes from non-ASCII editors
Can you attach the file here?
06 Dec 2020 15:40 #191263 by Mmarmino
By:
sudo nano /etc/network/interfaces
and then manually edited in the interface.
so i guess the answer is GNU nano 3.2 editor
06 Dec 2020 15:48 - 06 Dec 2020 15:58 #191268 by PCW
nano should be OK
You can save time by setting the interface down and up manually
sudo ifdown -s
sudo ifup -a
rather than rebooting when testing your edits
Last edit: 06 Dec 2020 15:58 by PCW.
06 Dec 2020 18:30 #191282 by Mmarmino
didnt know if you literally meant -s or if i was supposed to put something else there.
ifdown: option requires an argument -- 's'
ifdown: Use --help for help
auto eno1
iface eno1 inet static
address 10.10.10.1
netmask 255.255.255.0
isnt woking either
06 Dec 2020 19:28 #191284 by PCW
Sorry its:
ifdown -a
If the interfaces file do not make the expected
changes in the "ip a" report it usually means there is an
error in the interfaces file
06 Dec 2020 19:37 #191285 by Mmarmino
mmarmino@debian:~$ sudo ifdown -a
[sudo] password for mmarmino:
ifdown: /etc/network/interfaces:1: misplaced option
ifdown: couldn't read interfaces file "/etc/network/interfaces"
Well thats what i get! Ive followed another persons bench top mill conversion and we have the same components. If something is wrong with that file could i replace it with his if both setup are identical?
06 Dec 2020 19:54 #191286 by PCW
You could also try mine:
File Name: interfaces.txt
File Size:0 KB
06 Dec 2020 20:19 #191288 by Mmarmino
well that seemed to work! now i have a ping and can see it. Are these numbers better?
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data.
64 bytes from 10.10.10.10: icmp_seq=1 ttl=64 time=0.173 ms
64 bytes from 10.10.10.10: icmp_seq=2 ttl=64 time=0.170 ms
64 bytes from 10.10.10.10: icmp_seq=3 ttl=64 time=0.251 ms
64 bytes from 10.10.10.10: icmp_seq=4 ttl=64 time=0.171 ms
64 bytes from 10.10.10.10: icmp_seq=5 ttl=64 time=0.245 ms
64 bytes from 10.10.10.10: icmp_seq=6 ttl=64 time=0.188 ms
64 bytes from 10.10.10.10: icmp_seq=7 ttl=64 time=0.175 ms
64 bytes from 10.10.10.10: icmp_seq=8 ttl=64 time=0.243 ms
64 bytes from 10.10.10.10: icmp_seq=9 ttl=64 time=0.246 ms
64 bytes from 10.10.10.10: icmp_seq=10 ttl=64 time=0.249 ms
64 bytes from 10.10.10.10: icmp_seq=11 ttl=64 time=0.181 ms
64 bytes from 10.10.10.10: icmp_seq=12 ttl=64 time=0.259 ms
64 bytes from 10.10.10.10: icmp_seq=13 ttl=64 time=0.260 ms
64 bytes from 10.10.10.10: icmp_seq=14 ttl=64 time=0.242 ms
64 bytes from 10.10.10.10: icmp_seq=15 ttl=64 time=0.243 ms
64 bytes from 10.10.10.10: icmp_seq=16 ttl=64 time=0.269 ms
64 bytes from 10.10.10.10: icmp_seq=17 ttl=64 time=0.263 ms
64 bytes from 10.10.10.10: icmp_seq=18 ttl=64 time=0.251 ms
64 bytes from 10.10.10.10: icmp_seq=19 ttl=64 time=0.185 ms
64 bytes from 10.10.10.10: icmp_seq=20 ttl=64 time=0.240 ms
64 bytes from 10.10.10.10: icmp_seq=21 ttl=64 time=0.264 ms
64 bytes from 10.10.10.10: icmp_seq=22 ttl=64 time=0.236 ms
06 Dec 2020 21:28 #191292 by PCW
Not great but probably OK,
Worst case you may need to reduce the servo thread rate
from 1 KHz to 500 or 750 Hz
The following user(s) said Thank You: Mmarmino
Moderators: PCW, jmelson
Time to create page: 0.114 seconds
