Retrofitting maho mh 1000t
11 Feb 2021 10:52 #198381 by db1981
Replied by db1981 on topic Retrofitting maho mh 1000t
Hello,
can you post pictures from the old control panel and the control in the cabinet?
I think i remeber that the 332 control is only an labeld Heidenhain TNC335. If this is so than there is no output for ttl signals. That G6 card is the whole Axis Controller, may be you can indentify the interpolator circuit and solder wires direct to the pcb. But that will be no differential signals.
11 Feb 2021 11:10 #198383 by db1981
It is an TNC355, look here Page 16
product.heidenhain.de/JPBC/image/FILEBAS...C/605716_00_a_02.pdf
Usage of the board will be much efford. I tryed this years ago, the whole power supply with many different voltages musst run and some pins that normaly came from the cpu board has to be set. a pity that i have no longer acces to the schematics from the board.
I think getting 4 used EXE6xx would be much easier.
11 Feb 2021 14:42 #198402 by Sourabh3
Replied by Sourabh3 on topic Retrofitting maho mh 1000t
Hello db1981,
Just tell me if it's worth trying to figure out how to connect this G6 with 7i77? Can you be more specific about how can i find the TTL terminals from this board and can you tell me more about CPU terminals that you were talking about. In my country, i am not able to find exe 6xx cards. And also i don't know which EXE card will work with these linear scales. I want to reuse this card(if possible). Please guide me how can i do it?
11 Feb 2021 17:51 - 11 Feb 2021 17:53 #198422 by db1981
This will need some reverse enginnering from the pcb. you need electronics knowledge for this...
in the down left corner from your picture are the 3 interpolator circuits.
Scale input connector - input comparator (LM339 ??) - 3 mystic analog devices (A,B,Z) - then we got digital (resistor network, 74SN XXXX IC'S) there are the encoder pulses.
You have to measure the analog inputs (a/b) and compare it with the pins at the first nand gate from the digital site to find A and B. (min. 3 Channel Oszilloscope) .
But for this the control has to be alive. After this you have to try to get it work in standalone. There must be an Common Clock for all three Axis evaluating stages, came from an quartz, but i might remeber this was switched by an logic gate, this was the trick to get the interpolators running.
More i can't tell without an board or schematic.
EXE602 would be fine, 610 too but has not so an high interpolation rate.
Last edit: 11 Feb 2021 17:53 by db1981.
The following user(s) said Thank You: J Green
12 Feb 2021 05:57 #198497 by Sourabh3
I guess i should go with the 6xx cards instead of screwing up with this card. Can you guys tell me the exact model no. Of the exe card that i should buy for these linear scales? I have already attached the details of my encode earlier.
12 Feb 2021 09:51 #198509 by db1981
EXE602 would be nice.
your scales have an period of 20µ , with 5 fold interpolation through the exe you will get 4µ, after the quadrature counter(4x) in the mesa you will get an resolution of
0.001mm.
12 Feb 2021 09:53 #198510 by RotarySMP
Replied by RotarySMP on topic Retrofitting maho mh 1000t
Some 602's output 1µm and other 5µm (maybe there are others). Do a search of my 400E thread, and you will find the model numbers of the two I used, and their resolutions.
Mark
12 Feb 2021 10:00 #198512 by db1981
I have EXE602B and D , both have jumpers inside to change between 1 and 5 fold interpolation.
12 Feb 2021 14:21 #198536 by Sourabh3
Even the 602exe has several versions. And I'm having hard time finding which one would be best for me.
Moderators: PCW, jmelson
Time to create page: 0.205 seconds
